someone else brought up this point before - without the figures.
does it mean intercooler heatsoak is not an issue either?
Intercoolers are heat transfer devices, pipework isn't. Intercoolers have far more surface area, inside and out, so the air is in contact for much longer. Hence it has time to transfer heat.
Cheers
Gary
  • Replies 51
Posted Images
but whats sandwiched in the middle?
coz the one i used looks like wetsuit too.
Nothing?
If its the proper stuff it'll be pure material, some are think (4mm) and some are thicker.
Some stubbies have the foam and a layer either side.
Its like how many ways to skin a cat, many ways to make a stubbie holder :thumbsup:
Interesting.
To throw into the mixing pot, GTR factory rubber pipes into the IC and out of the IC... are insulated with a layer of some fibrous mat, then another layer of thin rubber sheet.
NVH reduction
Cheers
Gary
There are two different issues.
1: Heat soak at idle
2: Heat transfer on the move.
1. Heat soak for piping can be an issue at idle. Far less of an issue that that for uncovered pod filters however & not really worth worrying about.. The area the Gt-R has insulated is basically where the hot air exits the radiator.
Question - there is a temp read out available on the Power fc for the air inlet. Where is the sensor located?
2: Not an issue because the volume of air running through the inlet pipes is far, far larger than the transference of heat through it.
Question: If heat transference is minimal between piping and compressed air after the intercooler , why do we see intake pipes and manifolds being sprayed with nitrogen gas (or whatever it is) during dyno runs, i.e. at AutoSalon?
Edited by R338OY
I understand the flow characteristics of an engine.
Ohh, and this is on an RB20, 0.8bar.
I'm not so much interested in peak figures, ie.., wide open throttle, but also what it may do at other part openings of the throttle, or response, etc...
It cost me $16.50, and I think it's more than enough, worth a try no doubt?
Fixxxer
hmm, i'm very interested....
My cooler (GReddy type M) is really efficient. Qualify: the inlet side of the cooler is damn hot, can't hold hand on it for long after spirited driving, and the outlet side is quite cool, just like metal thats been out of the sun...
On the other hand, the pipework that runs behind the radiator is damn hot... I would be very interested in something that reduced the pipe's heat and also made it look less aftermarket when the coppers open the lid....
(I believe they wont be able to see the fridge door cooler at the front, they'll look straight past it)
According to Hot4's Which we all know is a great basis for tuning cars* supposedly the change in air heat during the movement through the intercooler pipes is about 0.02 so I say make up with that with a bigger turbo
Oh and if u insulate it, it also keeps heat IN
* Not entirely true and could be total misrepresentation of Hot4's
Oh and if u insulate it, it also keeps heat IN [/quote
Good point. I'd like to know what difference the ambient air passing over the IC piping behind the radiator makes to pipe temps. Maybe you're reducing possible cooling by covering the pipe up? Let's not forget all the air swallowed into the engine bay while you're driving. Again, can't assert much without some testing.
*lightglobe moment* what about an official SAU Laboratory which tests forum claims using empirical analysis. Good way to silence the noobs :D
Edited by R338OY
I'd go along with that in theory - amount heat transferred via pipework is negligible compared to that via intercooler.
But didn't the autospeed article state that there was 7-10°C drop? I can't ignore the empirical results.
Yes, quite rightly the insulation will keep heat in, but essentially the only thing heating things up is the radiator and underbonet temps. There is only a small amount of heat getting in from the connections (rubber/silicone) to the metal components (intake manifold). This small amount of heat when driving is negligible, and would be totally supressed by nice cold air out from the intercooler (which it currently does).
I will post back when I do the mod, including telling you guys if this stuff does work (cooler pipes remain cold), and any changes I notice by my bum dyno on response, part throttle and full throttle.
Fixxxer
To cool the air below ambient by making the I/C itself colder than the ambient which is what most I/C's are only even going to achieve, a few deg above ambient.
The gas super cools the I/C and thus brings intake charge down markedly
Similar in purpose to a dry ice cooler.
Sydney kid made a few good points..
has anybody thought a little out side of this box though?
What i mean is that the intake manifold is heated and so is the throttle body. So, wrapping the pipe probably wont do a lot for you..
If you live in tropical Queensland (like me), I bypassed the the throttle heater(not advisable if u live in snow, cos the throttle MAY stick!). That made a HUGE difference. the cruise intake temps went from around 78 degrees down to 45ish. Now to do the manifold is a different story. My point is this, IF you are really concerned about dropping more temp, then wrapping the IC pipping is way down on the list.
I wrapped my intake pipe ages ago in beer coolers, after i turned them inside out! I had it originally covered in fibreglass wrap which drove me made EVERYTIME my arm went into the engine bay.. so i swapped them. The pipe is cooler, looks ok in black and has shown zero signs of heat damage of any kind! That said, I only noticed the smallest of improvement, and that was from cruise onto boost.
I put this down to slower moving air that got heat soaked.. but that still doesnt really add up.
If your pipe looks crappy, then dont use beer coolers, go the wet suit option.
but try it out, i already had 20 or so beer coolers.. didnt cost me a single $ to find out!
That help anybody?
Ok, got some prelim results.
Used about 11 coolers, plus about 30cm of heat shield material from Clark Rubber (around over-engine pipe), about 95% coverage all up.
Today was a cool morning driving to work (city). Lots of idle time/stop start traffic.
Pipes = much cooler
Result = Fair improvement to response (from stop to building boost). Didn't have much time to explore on-boost due to traffic, but didn't see much if any improvement (too much airflow), not on my bum dyno anyways.
*Noted air intake pipe was a lot hotter than usual, this was due to longer idle times (more traffic). I have lots of heat shield material left, so will make a proper airbox for the filter.
Fixxxer
Ok, got some prelim results...
How ever much i might/might not, respect your "feel frmda ass" real numbers are important.... :D
*lightglobe moment* what about an official SAU Laboratory which tests forum claims using empirical analysis. Good way to silence the noobs :)
L0L
Edited by GeeTR
Yeah, sorry guys, this was never going to be a rigorous analysis of the results, I do not own a temp guage/thermocouple, it was more of a do it, see if it drives better analysis.
Result was much cooler pipes (hand test), on a drive more prone to heat soak (as verified by the hotter air filter intake pipe not insulated).
I don't know how much dyno testing has proved this (but dyno days with Cryo sprays/water spray on intercoolers has), but it's widely suggested that a temp drop of 4 to 5C yields approx. 1% more power.
Either way, the effect of cooler pipes can only be a good thing for power and/or efficiency.
Fixxxer
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
