Hey,
Just wondering if the DIN panel from JustJap fits straight into the console of a R33? Im planning on putting gauges under my deck (nothing is there at the moment) and was gonna make up a bracket to hold them. Although now ive seen this on JustJap and if it fits straight in that would be perfect!! Comes with 3 Gauges and a bracket to hold them!
Thanks! :blink:
http://justjap.com/store/product.php?produ...=267&page=1
Oh Really.... How come it didnt look good? Was it hard to fit? What did you have to do? Will I need to make up any brackets or does it just bolt up really easy?
so many questions! hahaha, just not sure how it would fit in.....
we just placed it in, didnt bolt it to anything. it will slip in behide the plastic bits of the dash (if you get what i mean) the reason i didn't think it looked any good was because the gauges dont sit flush. plus Chi used the cheap autometer gauges too which i think like crap in my opinion.
i will pm chi and get him to post a pic up for you
How come it looked bad? Was it a good fit?
I thought having 3 gauges under the deck would look good!
How did u install it in there? I dont get how people say they slide it in there? how does it hold in position? lol
So where did you end up putting it in the dash? Do you have a pic? :thumbsup:
yeah it did look crap cause it didn't sit flush hmmm i havne't got any pics it was ages ago but gotta thank mikey again for coming over and being my back yard mechanic !!! hah yeah man just get the defi 3 guage combo from nengun for like 400 or and it sits flush and looks great :thumbsup: +1 on china guages being crap hahah gimme ur apexi ones mike !
Autometer are a good brand for gauges... its the autogauge which are dodgy.. which are the ones that just jap are selling...
The GTR torque gauge shows how much is being transferred from the rear to the front end of the car, since it has an all-wheel drive system...unlike your rear wheel drive only GTS-T.
The 32 GTR one shows Voltage, Oil Temp, Boost, so might be more useful... but I'd get the defi one if I was you http://www.nengun.com/defi/din-gauge-rhd
Just noticed that the R33 GTR DIN gauges replace where the aircon unit is on the GTS-T. Will the aircon unit fit in another slot easy enough? Just wondering becasue the top slot has a corner on it.
Cheers!
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
    • Can you covert an R32's AC from r12 to r134 if the compressor/hoses etc are still all good? Pretty sure on my car the AC was degassed when it was imported  to remove the naughty r12 and save the ozone layer, and the fancy climate control system just blew air around. Was happy to drive the car with windows down back then, but now I am old and need to be kept cool
    • Just to circle back here, I've sold my automatic trans to another Stagea owner in OH.
