Quick question guru's...
GTRS turbo kit bolted to 33 gtst25t....
my current dump/front pipe is the big single 3 inch type....would I need to upgrade that for the GTRS to bolt straight (i.e. the split type?) upto or no need as it will hopefully bolt up?
Quick! before I pay for it lol
Cheers!
p.s. I dont want a debate on split pipes vs non - just need to know if it bolts up no dramas :blink:
Cheers,
Chris
https://www.sau.com.au/forums/topic/215383-gtrs-bolt-up-to-33/
different turbine housing which is more compact with the wrong flanges
different lines so you have to go and buy lines
different compressor inlet so you'd have to do something there
different compressor outlet
the list goes on.
Yes, the GTRS RB26 and GTRS RB25 are different.
Flange pattern T25 vs T3 is different from the start, so is the piping and so on id imagine to boot.
The poor man pays twice, buy the proper kit and save yourself a mountain of heartache.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
