About to slap on some more black stuff, who's had good experieces and with what brands?
Please put price paid.
I'm thinking the Faulken GRB's are hard to beat for the price.
What about the Dunlop sp9000's?
Or the Bridgestone potenza's?
Help!!
Sebaz
I'd recommend Michelin Preceda's. I fitted these recently and im very happy with them for the price paid (cheaper than other brands that were rated less by Wheels Magazine).
http://www.skylinesaustralia.com/forums/sh...ghlight=preceda
They pull up damn good too now that I have removed the glazing on my brake pads
http://www.skylinesaustralia.com/forums/sh...&threadid=21459
anyone else got some ideas?
I'm going 18 x 35 x 265 in size so a good wearing tyre with ability to handle a bit of power before spinning up is what I'm after.
Short of the Dunlop Formula-R's what else could I go?
Don't feel like paying over 2K for tyres this week..(insert large cough here!!!)
Sebaz
Originally posted by nismoman18
michelin pilots, real expensive however prolly just under $2000
Well as of about 5wks ago...
Michelin Pilot Preceda 225/50/16 = $235ea
Dunlop FM901 225/50/16 = $279ea
In the Wheels Magazine test the Michelins came first and the Dunlops were 4th or 5th.
That was enough info for me to make a decision.
I find em great, not too noisy, cheap, decent grip for the price range, 1.57 round eastern creek, no sign of wearing out yet.
Ive got em in 265 and 235 on 18s, so yeah, they are a bit noisy, I think any tyre is in that profile.
An interesting point just discovered is the lack of 265 size in the Dunlop fm901's.
they only go to 245 in 18's... lame...
So they're out then.
So it's the grb's and the michelin pilot preceda...
Last call for comments...
Sebaz
If you can find someone who stocks them you might want to look at the Kumho Ecsta MX tyre. I have 235/40 18's on the front of my 'line and they were a reasonable $360 each.
They are the best tyre I have used both on the road and the track and have excellent wet weather handling due to a fairly soft silica based compound.
Have only clocked up 5000kms so far but they appear to be wearing quite well (even after 250kms at track days).
Also liked Toyo Trampio F-08's but they are as rair as hen's teeth and only lasted 20,000kms. Did give them a flogging though.
Z.
Sebaz - i am needing new tyres soon too... I had Pirelli PZeros on the stocky rims, they were just under 400 a piece if i remember correctly and they were fantastic! however, with 265/35/18 needed now, they'll be slightly more pricey.. i'll get the Falken GRB's.
Christian
Hi all,
Well they're on the car! I went for the ZE-326 Falkens. NOT the fk-451's.
In a 265/35/18 they're all about 400-500 a tyre but i got a good price on the ZE-326.
Not the top performing of the range but acording to the guys at Owen tyres, plenty good enough for normal-hard street use.
So far they feel alright, a shit load quiter than the Formula-R's that's for sure. I noticed the difference in grip straight away from those baby's.
But for 260 a tyre fitted and balanced I'm not complaining one bit so far.
I've got slicks for the track anyway.
The R34 GTR rims look awesome, super stoked!!!
Thanks to all who contributed with their 2c
Sebaz
i got quoted for 475each tyre for pirelli pzero for 235/35/19 on the front and 500ea for 255/35/19 on da back
that was bout 3 months ago so now that im gettin rims shortly ill be lookin into it alot more and detailed
cheers.....
www.freewebs.com/2BNVS_r33
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
