??? :D
Well they are special, the particular model isnt used in any other vehicle afaik? But, functionally, I didnt think they were any different to your stock standard turbo and wouldnt require any 'special' skillset to rebuild?
  • Replies 54
Posted Images
I agree, no special skill set to rebuild BUT the advise you get is critical. I have spoken to so many people who say that a 30/76 would be great in the M35. Jetwreck is running a 30/71 in his car and his car has a lot of lag.
I just had mine rebuilt as a Sierra Stage 1 (compressor =43mm / Exhaust = 45mm) and this is almost perfect IMO. There is some lag but not an issue to drive around but it comes on strong and what is equally crucial is the question, Is this the last mod you want to do?
The reason I say this is because my injectors are at 100% duty cycle at 6800rpm (or maybe a tad higher), so any bigger turbo will mean you need to think about new injectors and piggy back ECU.
Cheers
Andy
I don't think there is a model number written on it... I can check tonight if needed.
I would be giving the turbo ONLY to someone who has done this turbo before as it is special.
yeah im of a totally different opinion there hey. whats so "special" about it ?
i need MTQ to assess what will suit as a high flow
and need to know whats written on the body to give them some gauge of what will suit.
just because others have done them before and tell you cant get them done elsewhere doesnt make it true!
bb hiflow is a hiflow if theyve got the technical skills to do it then its much of a muchness really.
ive hiflowed a much tighter unit and half the sized housing with a GT25 bordering a GT28 inlet .. and 30/70 is possible as craig has one. i really dont see the big deal as theres massive clearence for maching the housing and the replacement catridge.
if someone says otherwise that noone else can do it but us.. . theyre probably saying that to get the business.
my money is on either a GT30/70 or a 2860RS GT BB for $1465 as a hiflow at MTQ and im betting its just as good as GCG or others have done and cheaper too :D
Edited by PetroDola
MTQ down here told me to bugger off, as did most of the turbo joints. They had never seen one before and it would take them too long to jig up on the lathe, for the amount they would be doing.
you should be going bigger injectors if youre at 100%. youre running the risk of detonation and a craig 'situation'
It only gets to 100% duty cycle at over 7000rpm, not where I drive it on a regular basis.
Also that does not mean it is leaning out it just means the car is not as rich as the computer would like it to be.
I will put it on the dyno in the next couple of weeks and that will give me an idea what is going on.
spray patterns and injector flow rates arent as good up in the high numbers. people dont upgrade to get more from the injectors, its so they can remain in the 'safe' area
anyway, get an adjustable FPR and up the pressure a little. youll squeeze some more out of them
And make it even richer down low perhaps?
Emanage... You know you want to. :D
I'm down for one if we can hide it properly!
can we make it look like a hitech amp in the boot ? lol
i can see it now..my emanage sitting on the passenger floor cables everywhere hanging from the dash, motorbike cop leaning in the window saying "well looky looky here then.. whats this all about?"
They fit quite nicely beside the stock ECU actually :D
hahahaha i had one double-sided taped next to my knee in my S15. cops would look at it and ask what it was, i mostly told them it was a mobile phone charger, thats what the USB port is for lol
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
