Hey guys I have a question about the power fc that i couldnt find an answer to.
I recently bought a second hand power fc and was told by the guy that had it that my car wouldnt run on it (he had monster turbo, cams, injectors etc).
So heres my dilema, If i reset the power fc, will it go back to the base map they are purcahsed with (fingures crossed)?
or will I have to find someone who has the map saved so I can download it?
The reason I am doing this is so I can check everything is ok before making the 6 hour drive to my nearest tuner. :D
Thanks for any help.
https://www.sau.com.au/forums/topic/215418-apexi-power-fc/
yeah can reset it back to original settings no worries. SHould never run a tune from one car on another, no matter how similar or different the engine mods are. always start a tune frlom scratch.
you will be fine to reset it, plug it in, and drive to ur tuner. just make sure you follow the instructions. do a serch for power fc, paulr33 has done a hgell of a write up on them on here.
https://www.sau.com.au/forums/topic/215418-apexi-power-fc/#findComment-3805704
Too easy, just bounce it and your away. Rem not to load the car up till tuned.
I know when i fitted mine, even before tunning it was a fair deal more responsive down low, as it had a lot more ignition then stock... which coulda been an issue if thrashed on a hot day, with bad fuel etc.
https://www.sau.com.au/forums/topic/215418-apexi-power-fc/#findComment-3808214
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
