Apexi Power Fc
bilbo117
 Share
Hey guys I have a question about the power fc that i couldnt find an answer to.
I recently bought a second hand power fc and was told by the guy that had it that my car wouldnt run on it (he had monster turbo, cams, injectors etc).
So heres my dilema, If i reset the power fc, will it go back to the base map they are purcahsed with (fingures crossed)?
or will I have to find someone who has the map saved so I can download it?
The reason I am doing this is so I can check everything is ok before making the 6 hour drive to my nearest tuner. :D
Thanks for any help.
yeah can reset it back to original settings no worries. SHould never run a tune from one car on another, no matter how similar or different the engine mods are. always start a tune frlom scratch.
you will be fine to reset it, plug it in, and drive to ur tuner. just make sure you follow the instructions. do a serch for power fc, paulr33 has done a hgell of a write up on them on here.
Too easy, just bounce it and your away. Rem not to load the car up till tuned.
I know when i fitted mine, even before tunning it was a fair deal more responsive down low, as it had a lot more ignition then stock... which coulda been an issue if thrashed on a hot day, with bad fuel etc.
 Share
