GTRNUR Posted April 18, 2008 Share Posted April 18, 2008 Hi all, Im investigating stroker engine recipie's. How does the spacer block get attached to the top of the rb26 block? I presume there is some drilling and bolting down of additional studs to locate the plate while it and the bores's are bored out for the sleve's? Last question... How is the spacer sealed to the top of the block so there is no water or oil leaks? is the spacer block o-ring'd around ther water galleries and perhaps using a copper gasket around the oil galleries... or do they block oil all together and run external oil lines? Or perhaps part or all of the above? Just curious.. Cheers, Ian Link to comment https://www.sau.com.au/forums/topic/215431-rb26-strokers-using-a-block-spacer-how/ Share on other sites More sharing options...
crack Posted April 18, 2008 Share Posted April 18, 2008 can't tell you much but here's a pic. Link to comment https://www.sau.com.au/forums/topic/215431-rb26-strokers-using-a-block-spacer-how/#findComment-3806149 Share on other sites More sharing options...
GTRNUR Posted April 18, 2008 Author Share Posted April 18, 2008 Was just looking at that same pic not long ago. Rb30 or RB31 race engines. Billet crank etc... very pretty! Link to comment https://www.sau.com.au/forums/topic/215431-rb26-strokers-using-a-block-spacer-how/#findComment-3806153 Share on other sites More sharing options...
Adriano Posted April 18, 2008 Share Posted April 18, 2008 Im pretty sure they run an mls gasket under the spacer, although i feel this sounds a bit dodgey. Link to comment https://www.sau.com.au/forums/topic/215431-rb26-strokers-using-a-block-spacer-how/#findComment-3806160 Share on other sites More sharing options...
Dahtone Racing Posted April 18, 2008 Share Posted April 18, 2008 just get an RB30 block and build it save the f**k around Link to comment https://www.sau.com.au/forums/topic/215431-rb26-strokers-using-a-block-spacer-how/#findComment-3806288 Share on other sites More sharing options...
R31Nismoid Posted April 18, 2008 Share Posted April 18, 2008 You'd think gasket each side of spacer. Extra long head bolts etc that go through the spacer to the block to hold it in place different belt and all that to go with it of course. Oil/water etc would meet, just makes it longer travel, although with oil mods probably some blanked off or restricted still Link to comment https://www.sau.com.au/forums/topic/215431-rb26-strokers-using-a-block-spacer-how/#findComment-3806289 Share on other sites More sharing options...
GTRNUR Posted April 18, 2008 Author Share Posted April 18, 2008 I thought the spacer would have been bored to the same size as the cylinder bores, and then the sleaves would be pressed into the spacer AND the block, holding the two together? I guess the sleaves would have to be decked to the same height as the spacer block while the spacer is torqued to the same spec it would be with a head on it, when there is a gasket under it. just get an RB30 block and build itsave the f**k around There are a lot of good reasons to consider going down spaced block path which i sure we dont need to debate here. Link to comment https://www.sau.com.au/forums/topic/215431-rb26-strokers-using-a-block-spacer-how/#findComment-3806303 Share on other sites More sharing options...
STR8E180 Posted April 18, 2008 Share Posted April 18, 2008 just get an RB30 block and build itsave the f**k around the OS giken RB30 stroke kit is alot less f**king around compared to using a RB30 block my is under going a RB30 + RB26 cylinder head in his R32 GTR and nothing fits he regrets not going with the OS giken 3L stroker kit now Link to comment https://www.sau.com.au/forums/topic/215431-rb26-strokers-using-a-block-spacer-how/#findComment-3807033 Share on other sites More sharing options...
GTRNUR Posted April 19, 2008 Author Share Posted April 19, 2008 That the reason right there. Its not as big a deal in a 2wd skyline (althoough it does take some effort), a gtr is a whole diferent situation. It makes looking at short rod stroker engines like the Tomei 2.8 kit and what Mark99 did with a 2.9lt in an RB26 block worth investigating. Link to comment https://www.sau.com.au/forums/topic/215431-rb26-strokers-using-a-block-spacer-how/#findComment-3807127 Share on other sites More sharing options...
Dahtone Racing Posted April 19, 2008 Share Posted April 19, 2008 (edited) the only thing a OS kit will help with fitting is the sump because you wont need an adapter plate your still gonna have issues with the height using an OS motor or an RB30 block personally i just dnt like the idea of spacer plates and extra gaskets etc i like to keep things simple i had no problems fitting my RB30 but then again it wasn't in a GTR Edited April 19, 2008 by Dahtone_Racing Link to comment https://www.sau.com.au/forums/topic/215431-rb26-strokers-using-a-block-spacer-how/#findComment-3807171 Share on other sites More sharing options...
