current setup is
3.0L
3.5inch dump to cat then 3" all the way
44mm tial gate with .9bar spring
6boost manifold
GT35/40 .82 housing
the car just cannot hold boost. its making 300rwkw at 4000rpm and just keeps going because it cant hold the boost.
wanted to ask the gurus out there wat are the main causes?
44mm gate cant possibly be to small?
Dump to big?
faulty manifold?
trying to dc the gate, so it shouldnt make any boost. which will rule out the gate theory.....
was wondering if anyone had any other ideas?
*******************UPDATE**********************
blue = with gate
red = without gate
its defiently the manifold. it just cant flow enough air.
next step is possibly redesigning the manifold to have 2 outlets merging into one or getting a new one.
or a bigger housing like mentioned above which i doubt will help due to the manifold.
on a positive note.....quite responsive as u can see lol
Edited by R34NRG
https://www.sau.com.au/forums/topic/215455-huge-boost-creep/
  • Replies 140
Posted Images
current setup is
3.0L
6boost manifold
GT35/40 .82 housing
Dump to big?
faulty manifold?
so boost is dropping off below the .9bar ?
or do you mean the other way around and boost is increasing?
boost in increasing...just keeps gettn higher and higher.
we set it at .9bar (gate spring) and it will go as far as 22psi
Edited by R34NRG
Drop the exhaust from the dump (before cat) and see what it does.
Failing that, DOUBLE check the gate is connected correctly (hoses are the right way around) sounds like it might not be as this can be a cause for it to skyrocket with boost for no reason.
After you find those two things out post back.
I would also up the gate spring to 16-17psi if your going to run over 20psi
do a careful dyno plot with the wastegate disconnected, the vac line
this will mean unlimited boost (almost like how it is now) so dont trash it on the street, dyno only
a great way to kill your engine is by stuffing around with the boost on a fresh new engine
if you get the same result, either the vac signal to the gate is incorrect or the gate isnt working correctly
how much boost do you want to run ?
gate is 100% connected correnty. one of the 1st things we done.
not so sure about taking off the exhaust.
wouldnt that cause spike and not creep?
the cars currently on a dyno as we speak......
we are dc-ing the gate atm to test that theory......if we dc the gate it should make no boost right?
we plannin to run 20psi for a start.....not sure how high we willl go
Edited by R34NRG
if the gas isnt being bypassed through the gate due to a flow blockage after teh gate - then this can cause the boost to creep - hence the suggestion to remove the exhaust
what boost controller you using? how many vacuum lines to the gate?
2 lines to the gate, they are the right way around as we checked them with a diagram (Me and the mechanic both went over it at the same time)
atmo gate, exhasut wont matter
boost controller is AVCR set everything to minimum (basically turned off) so should be running of the spring only.
current test is holding gate completely open to see if its flowing adequately
What do you mean your not so sure?
You dont even know whats causing it, drop the exhaust and see what it does... and double check the gate.
There isnt much to infinite boost climbs, its only a few things that will cause it.
blockage/restriction after the turbo or something not connected correctly before it
Exhaust WILL matter. Come here asking for help and then tell me it wont matter when you obviously dont even know?
Why ask for help if you know it?
found the issue.
droped the gate off and its still causing creep.
the manifold isnt flowing enough air to the gate so thats why its creeping.
very hard to believe being a 6boost manifold.....
only solution atm is possibly redesigning the manifold.
Edited by R34NRG
I dare say that the 6boost item is a tried and proven design, you are not the first to use it and many people before you have had no issues.
It seems you unfortunately don't want to listen to any advise given to try and help your cause.
Before questioning the work of someone else, do the VERY SIMPLE test:
- Unbolt the cat from the dump pipe and do a power run. A restriction in the exhaust causes back pressure, thus causing boost to creep/increase.
If you are not prepared to listen to any advice, best not to ask :P
What is the I.D. (Inner Diameter) of the wastegate pipe/flange, before the wastegate?
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
