Often removing one of the springs in the 1 bar gates helps, as does a change of cam timing, and also putting a proper cat in, the back pressure reduces boost. Simply put, if you want to run your car like a race car with a 3.5"+ exhaust, no cat and 1 muffler, then run a race style 50-60mm gate, don't expect to use the best manifold on the market thats is designed to stop turbulence, reversion and increase velocity, and expect to use a street style(for the application) 40-45mm gate.
6BOOST
i understand wat your saying about the 1bar gates and removing the spring, but it dosnt matter if the manifold is boostspiking with NO GATE at all. spring or no spring it aint gonna make a diff.
but its interesting that u only now mention a 60mm gate. i remember calln u and askn if a 44mm gate would be sufficiate enoguh for my setup. my tuner said it was, you said it, even other setups list a 44mm gate.
and all of a sudden the issue pops up and the answer is a 60mm gate.
modified the manifold for dual ports, cut the wastegate port off, and running with no gate. still overboosting. but it taps off at around 10psi and slows down to 13psi. which is alot better then before.
f*kn dont know wat to do anymore
apart from gettn a whole new manifold (which is bs) and a new 60mm gate (which is even more bs cuz we dont know if it will fix the problem)
  • Replies 140
Posted Images
I may be way wrong here as I play with smaller 4 cylinder engines that don't run split pulse housings. But when i look at the picture of where the WG piping comes off it looks as though it only comes off only one side if the split collector meaning that the other side is still being fed by 3 cylinders which are ungated?
i dont believe he runs a split pulse turbo.
You've been told how to fix it, yet your still here posting dribble?
for the love of god...
are u f*kn seriously just tryna piss me of off ash? or u clearly jsut cannot read?
gtfo.........u aint got nothing useful to say
its not split pulse
and yes u are right the wastegate port is one sided, which is why we made a 2nd wastegate port in the middle of the manifold so it gets air from all sides. Which then murges back before the wastegate.
but still over spikes.
no i dont =[
Edited by R34NRG
I think you should stop posting dribble, and take it off the forum.
Your not doing yourself any favours coming out and trying to get stuck into the manufacturer of the goods and having a good ole e-war with him.
Hardly tactful, hardly smart.
No offence taken, however to highlight the points you just raised, my gate outlet comes off the collector at 30deg, I cut every single one of them and put in a big box with my drop saw every few weeks, so I know the angle, maybe you haven't taken notice before. Secondly to that, the gate outlet pipe is 42mm id. A Tial 44mm gate(most common I and my customers seem to use) is measured at the valve, not the hole in the inlet, which is actually around 41mm or the same as the outlet pipe. The other most common gate is the turbosmart 48mm, which as a 45mm hole in the inlet flange, again, only 1.5mm per side bigger than the pipe I use, there is no such thing as 50mm pipe. Conversly, the next size up pipe has a diameter of 54-55mm ID, its so big that the gates we are talking about, the flange would fit INSIDE the gate outlet. This in my eyes would cause massive turbulence into the gate... Would the bigger outlet pipe make up for any downsides to the flange transition?? I don't know.
Simple fact is, if anyone has a probem with boost control, calls me, and actually listens to what I have to say, rather than just look for someone to blame, rarely can you not get a workable result easily. Its just most people want to listen to the advise of others, rather than the designer of the product who has done over 1000 manifolds and encountered every problem first hand along the way. Often removing one of the springs in the 1 bar gates helps, as does a change of cam timing, and also putting a proper cat in, the back pressure reduces boost. Simply put, if you want to run your car like a race car with a 3.5"+ exhaust, no cat and 1 muffler, then run a race style 50-60mm gate, don't expect to use the best manifold on the market thats is designed to stop turbulence, reversion and increase velocity, and expect to use a street style(for the application) 40-45mm gate.
6BOOST
my manifold came out at a 90deg angle to the flow, split pulse 90 degree t4 flange... i can run the lowest of 15psi on a tial 44mm and it creeps to 18psi, holds flat if boost controller is set to that and i dont mind because the motor can take it but if i wanted to run less boost i would have problems
another t3 flanged manifold we ordered you are correct it did come at a angle but we wanted to run a 60mm gate so we welded on a bigger pipe at the same angle as the original and works very well. it must have been a 54mm not 50mm my appologies, we have ordered the most recent one with no gate pipe at all. can you possibly make a option for people to have the bigger pipe when ordering?!?
as i said they are great manifolds and i recommend them to everyone, just trying to give you some feedback on my experiences
Had a chat to my mechanic and Andriano is partly right.
Even though i have a similar setup, with the same size ext housing on the turbo, you are running a bigger hp turbo, thus having a bigger ext wheel. The bigger wheel in the same size housing will not allow enough air to flow past through the housing without spinning the wheel faster and faster.
Two options: Upgrade to a 1.06a/r ext housing, will also give you better top end, or "bleed off" more gases (ie: larger feed to gate and larger gate or run 2 gates)
Either way not really the "fault" of the manifold design
Has anyone at R.E. rang any turbo experts (ATP, GCG, etc) to discuss the above mentioned probability, before hacking the manifold? They may have agreed that such a efficient set-up (manifold, exhaust, etc) will cause the turbo to keep boosting due to the smaller ext. housing and large ext. wheel of the turbo.
Putting a W/G at the base of the collecter is almost useless, as it is directly opposite the flow of gases. What do you think is going to cause the gases to do a u-turn, of flow, and exit out the 2nd gate, instead of continuing on through the turbo. If a 2nd gate was required it should have been placed on the opposite side, of the collector, to the existing w/g, at the same angle.
it is useless, especially if the hole is still only 44mm wide.....which is why we made a 2nd WG port in the middle of the manifold that captures air from all cylinders. but still didnt work.
might have to machine the manifold and the 2 gates to possibly 60mm and use a 60mm gate
the answer is not a 60mm gate, it is having the 44mm the right distance from the manifold as per kyles design.
Dood, make sure the WG piston is free to travel...take the spring out and physically pull the centre of the diaphragm... it should travel atleast 10mm...make sure the stem is not damaged...also make sure the diaphragm itself doesnt have a hole in it as well...connect a tube to the bottom port and blow into it and listen for leaks...apologies if this has already been covered...
unfortunately its not. we chopped the port off complete so its running straight from the manifold.
it did help....but still overboosting by 10psi......which i guess is livable....but still shouldnt be happening....and i dont want it happening
I would have thought the best way around this problem is to run the wastegate off the exhaust housing, as it should allow a better merge angle, but obviously space constraints may prevent this
but i shouldnt need do. theres 1500hp cars out there running a gate off a manifold with no issues at all, why the hell should i need to do it.
and its a shit way of doing things, to messy and no room. basicly it feels backyardish
its alright buddy, and it has
the manifold with no wg at all, with a big gapping hole is still over boosting, so even if i did put the wasstegate back on, checked the spring and everything.
it wont change anything
the manifold is not bleeding enough air quickly enough to the gate....for the gate to do its job.
it has nothing to do with the gate.
its simply the manifold.
the question now is how to get the manifold to flow enough, whether it be slammin the gate onto the exhaust housing, makn the wg port bigger on the manifold or dual porting it.
which i have tried all except the exhaust housing one(which i dont want to) and have all failed.
im thinking about possibly increasing the size of the dual ports.....and seeing how that goes.....
Edited by R34NRG
Shit...never heard of anything like that before....when you start the engine with the WG off does it feel like you are getting a lot of exhaust flow out of the WG flange...(just wondering if they may have f**ked up somewhere in the fabrication. ie not drilled where the WG pipe is welded onto the manifold...remote possibility but you never know...
the manifold was designed with the wg port on one side.....which was a lil weird because it looked like it was only able to get air from one side.
which is why we made another one in the centre that catches from all sides, that merges back later
previously boost wen spiking over 15psi and still climbing with no end.
but now its taping off at around 10psi and then holds at around 13psi. which is okai but id rather see it down around 5psi.
just some reading i've done has shown up another RB30DET, running the same gate, same turbo, in general a very similar setup, only major diff is the manifold. this car holds 11psi, and keeps it there. car runs standard cams etc too i think
and andrews car is running 3" catback exhaust . surely you would not expect anything more restrictive than that? *no cat apparently*
gate will not be welded to the exhaust housing, its just not happenening.
Edited by VB-
do a careful dyno plot with the wastegate disconnected, the vac line
this will mean unlimited boost (almost like how it is now) so dont trash it on the street, dyno only
a great way to kill your engine is by stuffing around with the boost on a fresh new engine
if you get the same result, either the vac signal to the gate is incorrect or the gate isnt working correctly
how much boost do you want to run ?
we plannin to run 20psi for a start.....not sure how high we willl go
im still confused
put the gate on the manifold and set it all for 20psi .. does it make and hold 20psi ?
i can see you saying to want it to run as low as 5psi ... but why ? there is no benifit of a setup that can run 5 psi, since once you get it to run 5psi .. you'll need to upgrade the springs to get it closer to your target.
im not having a go here, im just trying to suggest working for your target boost number OR power target and not well below it is the best approach.
im still confused
no no no, i dont want to run 5psi. i want the manifold to hold a max of 5psi with no gate. because we already identified that it was the manifold that isnt able to bleed off enough gas to the gate, which creates infinite boost.
with the gate on and and set to .9bar from the wastegate, it made 15psi at 4000rpm and kept rising. you could tell by the boost cruve that it would kept on going, even past 20.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
