I could be wrong here but I believe dropping the exhaust won't help..if anything I believe the exhaust would need the restriction to slow the exhaust wheel down.
To make boost with no wastegate attached seems to be more manifold issue.
Anyway, we'll drop the exhaust and see how it goes.
  • Replies 140
Posted Images
I dare say that the 6boost item is a tried and proven design, you are not the first to use it and many people before you have had no issues.
It seems you unfortunately don't want to listen to any advise given to try and help your cause.
im with you on the 6boost thing. i dont really think its the manifold either.
all i said is i wasnt sure about the exhaust....as in i dont know if it is....because we were testing the gate issue at the time...
never said i wouldnt do it....
if the gas isnt being bypassed through the gate due to a flow blockage after teh gate - then this can cause the boost to creep - hence the suggestion to remove the exhaust
what boost controller you using? how many vacuum lines to the gate?
the gate is atmo, its not connected back into the exhaust.
the gates been removed which means it shouldnt make any boost.
but it is, which means theres pressure being made by the manifold. because it cant be anything after the gate....cuz there is nothing....
which means theres something wrong with the manifold......
of course this is only theoretical....and it makes sense
rather then taking off the exhaust....and seeing wat happens
Edited by R34NRG
on your dyno plot get ray to plot manifold pressure if you can
youll probably see its ramping off its ass if the exhaust is very restrictive
does the power / torque plummet after aroudn 4 grand?
but i dont see how the exhaust even matters if the gate is fully open.....all the air should be passing through the gate and not the exhaust?
i can only assume power/torque keeps going cuz ray said he had to back off because boost was reaching points of 20psi+ when we turned the boost control off and using the gate spring of .9bar
but ill have to ask and make sure
Edited by R34NRG
no the wastegate is purely designed to reduce backpressure in the exhaust manfiold
its not meant to make all the gas flow through it, otherwise the exhaust wheel would slow down and loose speed, thus loosing boost pressure
so when the gate opens, the exhaust wheel should stop increasing speed (ie: boost should stop climbing and stay even) and all things run happily
if the exhaust wheel keeeps increasing in speed, boost climbs, so its possible the exhaust manifold has tons of pressure built up and stuck inside it
which drives the exhaust wheel faster and faster, much like ":unlimited boost:".
why did you choose 44mm
backpressure because of a crap exaust causes boost to drop off though doesnt it? not creep. 44mm gate was what i told him to get, and i cant see how it would be too small.
im still having trouble figuring out how a restrictive exhaust would cause a turbo to spool with a 44mm gate held completely open?
that all makes sense but wat im trying to say is that when the gate does fully open....its still not expelling enough gas in the manifold, which keeps the turbine spinning. which causes boost creep
this means a few things
manifold isnt gettn gas to the gate
or
gate isnt lettn enough gas out
i dont know why everyones talking about the exhaust...because the cars creeping even wen the gate is fully open WHICH is suppose to let all the gas through the gate and not the bloody exhaust. so taking off the exhaust wont do jack.
i got the 44mm cuz everyone said it was big enough. tuners, shops, forum members, everyone. even other ppl using similar setups are using 44mms.
are u saying its to small?
Edited by R34NRG
A proper 350rwkw/GT35 set-up needs at least 3.5" without gate ATMO especially if your running a 3ltr, cams etc...
A restriction wont slow the exhaust wheel to the point of stopping boost production at full throttle, the turbo will still be making boost from the front end as the exhaust has already been produced & feeding the rear end.
Residual is sitting around causing pressure build up as the motor is making more and more exhaust so its gotta go somewhere and that air is moving faster and faster to attempt to get out.
That's a possibility for what's occurring here and that's my understanding of how it works in a non-educated way :laugh:
If you think the gate is too small - easy to tell that too. Take the thing off and see what happens, another 5-10mins task :down:
theres plenty of 350+ cars out there running 3" all the way with no problems. although i do understand the bigger the better. i think 3.5 to 3" is more then enough on this application. and like i said before it shouldnt be related to anything about the exhaust because when the gate is FULLY open its still creeping
no shit.......thats wat im saying, there IS a RESTRICTION somewhere which is causing the exhaust wheel to spin moreeeeeeeee and moree and moreee....not just a lil
If you think the gate is too small - easy to tell that too. Take the thing off and see what happens, another 5-10mins task :laugh:
found the issue.
droped the gate off and its still causing creep.
the manifold isnt flowing enough air to the gate so thats why its creeping.
very hard to believe being a 6boost manifold.....
only solution atm is possibly redesigning the manifold.
read much ash?
Edited by R34NRG
damnnn beaten to it
im gonna be a man here and ask everyone to keep on topic. as much as i would love to take the piss out of ash like he always does to me. ill take a raincheck....
so just to make it clear to everyone.
the car is still causing creep even with the gate off the manifold. stop talking about exhausts cuz its not related.
it has to be the manifold.
but hang on, its 6boost so it cant possibly be it right? i mean its impossible to imagine maybe there might be something wrong with it because a human made it....right
Edited by R34NRG
Yeah did that, about 4000rpm its making 5psi of boost and still climbing.
its strange cuz Mavrics is using the same manifold design and same gate. Had no problem with his. maybe its just a 3 ltr banga motor :laugh:
Oh well first thing on monday we'll drop the exahust and see how it goes.
I think we need another or larger port from the collector.
We'll keep you updated
IS it a built motor with headwork and cams? My guess at this stage, is:
A .86 ex housing is a little small for an rb30det, and if it has cams etc, that would make it worse
A 44mm gate is a little on the small side if you are trying to run low boost.
Ivve seen this same problem on Todd Wilkes 1400hp Gicottolo, boost was going off the dial with the wastegate valves installed backwards it had twin gt35r .86's(if i remember correctly) twin 50mm wastegates on a built 5.8. The night between qualifying and comp at summernats we pulled the turbos off and machined the ex housings 1.5mm(and wired in an autronic) Fixed the boost control.
VB-, if your just going to be a parrot, go to the wasteland.
To date you've offered nothing useful to this thread other that repeating everyone else in the thread because you don't know anything on the subject.
I've said my bit, you don't want to do a 5min check, no problem :laugh:
Andru, you'll never take the piss outta me when you make yourself look like a silly ass with each post you make here :down:
What turbo is Matt using Ray? Is he 3ltr or 2.5?
I cant remember his setup at the moment as he's changed it more often than i used too :down:
If its the same manifold design and its working on near-similar setup i'm surprised as i know Matt's is going a treat :(
No doubt the motor is tip top... just don't tell the Mav someone got a better one lol
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
