Hi,
I have a Jim Berry race clutch and a noise has just appeared which is when the clutch is not depressed it makes a sort of squeal, depress the clutch and the noise goes away i have searched the forum but everything relates to a noise when the clutch is depressed it isn't slipping and i can go through all the gears just fine even if i give it a little it grabs and goes to gear just when it is not in use i get this squeal very annoying can anyone suggest what is going on??
https://www.sau.com.au/forums/topic/215516-r33-squeaky-clutch/
im confused...not depressed means its not not pressed which means its pressed then? and it goes away when its not pressed? if its a whirring sound its probably the thrust bearing, but that goes away when the clutch is pressed (not depressed?) ha....
oh jesus now im confused lol but yea to clear things up when my foot is not on the clutch it makes the sounds....put my foot on the clutch sounds stop.
