Fatal Dyno Accident
In which case I still think my approach would be just as easy. In fact, easier, because of all that guidance on the front side.
I would be very surprised if you could tell the difference between 8kg and 12kg wheels in a blind A B test. What you will be able to notice is going to wider wheels (+wider tyres). If you don't have to abide by any rules, I'd fit the widest wheels you can get under the guards. -
To this day I find the stock R32 wheel size hilarious.
I mean the stuff on the side. It really depends on what the JSAI bar has - I'll make the assumption it has the strakes and that the end is just a flat piece. Otherwise....
Are you talking about the hole at the back end that is just a hole (albeit one with some shape to it, as you perhaps say), or are you talking about the big strakes that run down the sides of the recess?
