hi guys, its about my R34 headlights
i got this yellowish mark inside my headlight, well i dont quite know how to explain it but you guys probably know anyway the good old mark in old car headlight..
question is simple how to get rid off it?? :P
I want it to be nice clear and shiny, i asked a guy who sells HIDs but he said if he opened it up, polish it, and close it again, it wouldnt be perfect and when rain comes, some water vapour will get inside and shit and leaves water marks..
cheers
https://www.sau.com.au/forums/topic/215569-cleaning-headlights/
This has been covered many times before mate. Next time do a search, but you can just use and polish to remove the yellow cover depending on how bad it is. If something like Maguires Scratch X doesn't work then you'll have to open up the head light. To do that, you'll need to put the headlight in your oven to melt the glue, open, clean, etc.
The reason the HID guy told you it won't be perfect is because most people don't buy new seals, they just re-heat and stick the cover back on. If you got new glue to seal it up, it should be like new.
just use some cut and polish . kitten works well , then use something smoother . buff it well with heaps of elbow grease. i sanded my headlights right back from 400 gritt all the way to 2000 gritt . they turned out un believable. i also did it to a friends car , and the sprayed his headlights with clear gloss and they havent got yellow ever since. perfection
:D:(:) guys, c-red actually polished my headlights when i did my 10k service, he uses some kind of japanese plastic cleaner... :D GO JAPANESE!!
works excellent, was very happy, and the guy said u can get similar plastic cleaner from super cheap auto, so im gonna do that the next time its need a clean!!
thx for the reply anyway, prob solved :D
eyy buddy their is this stuff that looks like cut and polish, but you just rub it on the headlights and it gets rid of all that shit... my mate showed me it i can get you the name of it if you like. but it does a bloody good job lol
Permatex, Headlight restoration kit. This involves wet sanding your lights with a fine wet dry in 3 stages. then using the plastic polish supplied in the kit to finish it off. 30 bucks a kit does 2 lights easily. I have used it and it goes awesome.
If you have mad yellow lights you just sand more. you see it all come off in the water you sand with. then the polish smooths the scratches and your lenses are clear again.
I know Autobarn stock this. But i suppose anyone who stocks permatex can too!
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
