  • Replies 76
one thing that all rb motors are going to need at one stage or another is a overhauled ignition system, wheather you go for replacement direct fire, or go for a wasted spark system, this is just as good as putting a free flow exhaust manifold.
you notice the difference.
you'll have money left over to buy a programable rom for your ecu.
your a goose.
i have over 350 rwkws with the standard coils and ignition system, running 24psi daily.
would you like to respond to this?
My advice:
get a bigger dump pipe and front pipe (does not have to be split, the big bell mouth ones work well too). also doesn't have to be new either. That will be anywhere from $250 to $500 depending on what you get and if it's new or used.
then I would get your ECU chipped and tuned. the toshi remap seems to be popular. when you get this done also fit a cheap bleed valve and up the boost to 11 or 12psi even that extra 1 or 2 psi will make a difference and make the car feel a bit nicer. The remap and bleed valve will eat up the rest of your $1000 budget. but you should get some good gains out of those mods. :down:
Mate I am actually in the same boat as you except I have an R34 GTT - currently has cat-back (came free with car) and boost controller ($30) running 10-12psi. I also want to spend minimal money - My plan is:
Dump pipe - $199
Hi Flow cat - $160 (you already have this)
FMIC - $300 (not really needed but hey I like the look).
SAFC NEO - $250 (brand new delivered, buy from the USA dont get ripped off here)
Tuning for above - $100-200.
Thats $1100 for me or $649 for you (as you have cat, R32 wastegate (10psi) and dont need FMIC). Personally I think SAFC is a wise investment, these cars run sooo rich with exhaust...I get 350km to a tank driving normally, everything is serviced/new, which leaves the air/fuel tune.
I only have one rule when modifying and thats make sure everything you buy can be taken off and sold seperatly when you sell the car, i.e. KEEP ALL YOUR STOCK PARTS. End advice.
Hey thanks for that!
Would you maybe pm me the details of where i can get the SAFC?
Whats the difference between the toshi remap, the jaycar fuel controller and the SAFC tune?
I havn't looked in a while but I just did a google search of US performance shops - also US Ebay had multiple new SAFC NEO's for under $300 delivered to your door in Aus.
^^ Also in responce to Decim8 I have had multiple X-Force exhausts (previosly on a WRX and a VR4) and never had any problems with them, why pay double for a brand name? But thats just my opinion not saying your wrong.
if you shop around you should be able to get a FMIC kit and front section of your exhaust for $1000...
You should be able to fit it all yourself, they are both easy to do if your not confident just take your time...
I think the best mods are the one's you d yourself a lot more rewarding.
I speak from experience when i say
get someone to fit the dump for you!
Good luck trying to undo the stock screws without snapping anything.
Is a Nistune ROM and remap essentially the same thing?
Hyperdrive in W.A say they can remap it and tune it for $800.
Is that reasonable?
Also, i have heard that remaps are better then a SAFC and tune, but i have nothing to base that on.....
Nistune is an advanced re-map. It accepts live changes making it easy to tune.
It also comes with software pretty much featured to the level of a power FC.
I had two rb20 cars.
One got an SAFC and 14 psi and the other stock boost and nistune.
http://butters.throwinghandles.com/file_st...veditvsSafc.jpg
Thats the comparision graph. The nistune does make less power but that is only becuase it has no extra boost.
You can clearly see the difference in the quaility of the curves. I won't buy an SAFC again !!
Driving them is worlds apart to the Nistune is so much smoother and feels almost as fast as the higher hp tune.
OH and as for SAFC not making any more power.
sus out this before and after SAFC.
http://butters.throwinghandles.com/file_st...fcTuneSmall.jpg
the AFR's of the scale without the SAFC and thats just with cooler, zorst and boost.
i think in the end you gotta try things for yourself...
i have been running 14psi with the stock turbo and smic on my 32 for 2 years/50000'ks and its still going strong....
i also have one of those china manifolds that is supposed to crack a week after you buy them and mines been fine for 50000k's
of all the mods i have done i have found that good tyres are the best bang for the buck.....
i have one of those ecu remaps and i can hardly notice the difference...
taking out the sub, rear seats and all the trim behind the front seats made heaps more difference..
but changing the castor, and camber bushes to adjustable did f**k all..
thats me and my situation its gonna be different for everyone...
Ok here's the update...
Dump is definately on the cards, i thought i might first just try to source something decent second hand. Anyone?
As for remap i did some research and spoke to Toshi (Great guy who knows his stuff! Thoroughly recommended!), he was even kind enough to show me what he could do on my car with the road tune, try before i buy type of thing which was a real learning curve for me. BUT even though my car is still as i first posted as i didn't really feel any more pull from the tune, a smoother overall delivery of power definately, but not any more pull. Toshi recommeneded i try a front mount, dump pipe, hiflow, fuel pump and airflow meter to really make the most of the tune, which i can appreciate but i'm not going to do...
Toshi spent a long time and did a great job but i just think my mods i have done even when i get the dump pipe can't justify the tune... not just the money side of things but just the fact it didn't change a hell of a lot with my setup..
I'm not sure if anyone else has experienced this with same mods?
So i'm still not sure what to do next...
A few have said boost controller and up the psi but my friend had a bad experience with boost creep in his 33 with similar mods except for FMIC snd dump pipe and blew the turbo, which kinda scares me off.
The R32 Rb20 has less ariflow than the Rb25 in the R33 gtst and as such the turbo can tollerate a little higher boost, as at the same pressure the Rb20 airflow is lower meaning less shaft speed on the turbine. Less power too.
No one has really mentioned replacing the 02 sensor?? Have you replaced it since youve had the car?? if your going to put on a dump pipe you may as well spend the 100 or so bucks for a new one as you can remove the old one and install the new one while the dump is off? good for a few kws i guess if you still have the tired old factory O2 on there. i believe they are supposed to be replaced every 40,000ks or something??
but yeah definitely go dump pipe/hi flow cat converter first
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
