so this guy i know is buying an sti wrx. the previous owner is claiming a wsid quarter mile of 12.1s with only 205kw at the wheels.
i call bullshit. how can that be possible? i reckon youd need the best part of 300 to get a gtr down the other end in 12.1.
thoughts?
https://www.sau.com.au/forums/topic/215631-121s-with-205rwkw/
umm try 11.7 for 300awkw gtr... :)
Edit: just realised what i wrote.. 11.7??? for 300awkw?? oh god.. the stock R35 with less power does it faster.. all because of its super gearbox.. :D
Edited by Bumblebee
thoughts?
300? I reckon you need to research :D
A GTR can get into the mid 11's with stock turbos if driven hard. So around 250awkw is all.
No, 250rwkw if that.
Its all about tyres and practice mate.
I went 12.9 with 210rwkw back when i was racing (1400kg), and that was 225 street tyres, semis/slicks would be mid-low 12 no problem.
phwoar. i reckon ive got about 250, so we might give it a good shake! smash all the hsvs there running 14s.
one more thing, since you appear to be a source of much knowledge. ill chuck v power racing in, 100ron. is it worth getting booster? much more powah? bad for engine etc?
No point without tuning for the fuel really.
But wouldn't it be a good idea to prevent pinging? I know its a good idea on the track but since the drag is soooo much shorter is it even worth going a higher octane fuel?
My mate does 12.2 in a 280awkw GTR, with 4WD problems. He could do even better.
Isn't it 5-10% ethanol? Not recommend for your car, can damage the injectors. A one off? Then i wouldn't worry.
    • Sigh... yeah OEM mount rear battery, very R33, very demure, very mindful.
    • Would need a substantial current draw in the car to make a bunch of sparks. Obvs to now test resistance to ground of the car's B+ lead. If there's a short there, you'll see it. Only likely place for that, as you suspect is alternator. But there is also the possibility that rats have had a chew on some insulation. Shitbox has the battery in the boot, yeah? Plenty of cable to attack.
    • Oh, I thought of that too... I disconnected the battery and hooked up the leads direct to the car without the battery in place. Sparks... I suspect the following: Alternator has decided to kill itself Starter has decided to kill itself I'll recharge the battery, then unplug both, and go from there. The above might take 6 months - however I did buy a Victron 15 AMP trickle charger, apparently it's better than CTEK? Amazon, delivery by tonight. https://www.amazon.com.au/Victron-Battery-Charger-15-Amp-waterproof/dp/B07P4LMMMD?ref_=ast_sto_dp
    • Test actual voltage on battery. It's probably way low and possibly got a shorted cell. Something that might explain everything in your report.
    • In other news, my shit box R33 is Gregged. I kid you not, 3 months ago it drove perfectly fine, parked it and it sat on the trickle charger for about 2.5 months. A few weeks ago, noticed the charger stopped working.  Oh wells, 15 years out of a CTEK charger, across 3x shit box JDMs (and other dailies) you've done well. Went to try start the car today, nothing. Thought, yeah ok, let's get the jumper leads on. This is where shit escalated lol... Initially popped on the leads and noticed a great deal of sparks, not to worry. Let's triple check shit and try again, yep same. Thought perhaps was just an initial current draw from the 2x audio amplifiers, etc. nope, leads got warm and the fuse box jump point started to GLOW! 🥲  Luckily the Tiguan wasn't on, I can't imagine what Christmas lights combination would have appeared on the dash if the motor was running. Anyhow, hastily gave up and messaged Brett for a laugh, or commiserate whatever you want to call it. Skyline (Shitbox) Lyfe 😂
