im doin wat he is^^
car's got no seats/carpets atm lol
next time...
so mine has 2 seats an floor carpet.. u soft 34 boys lol..
i will be there, yes im at my girlfriends house and yes i will be coming in work clothes...
can we have a meet 2moro night i got blue smoke tyres lol
  • Replies 52
yeah everyone was there....i had trouble finding it cos i didnt realise it was at the back!
sorry to the guys who i said i was coming down to kmart but my friend took ages to rock up! good meeting some of you guys.
Far out, that was a hike!
Just came back from where u guys were..
thought it was organised for the safeway roof top..get there no one is there..
anyway drove past image, bf didnt wana stop coz there was only 3 cars :D
10-12 cars, there for sure... although if your posting at 7:34pm, and the meet was 7:30pm... then you were probably far too early?
Good to meet people, sorry i'll forget a few names though, im a bit hopeless with that :)
See people again soon no doubt in my own car
yeah man. another one.
i think its due to constant compressor surge. even when i back off on light throttle i get it. at high rpm i dont get a woosh from the bov. all i get is high pitched compressor surge
maybe its due to squashing my stock bov and putting a fan screw in the bleeder of it.
oil pressure seems fine. when i boot it goes to about 5. cruising about 4
I wouldnt go off the stock gauge... plus thats reading @ the sender... over @ the turbo is half an engine bay away, could be a blockage in a line or something that wont show up on a gauge etc.
could be comp surge... but i doubt it that soon
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
    • Transplanting the vvt from a 25neo into an rb26?
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
