Hi, Recently bought a R33 GTS-T, was running alright at 10psi boost with a boost controler joined to the exhaust side of the turbo and not joined anywhere else from the outlet point on the controller. At high boost it was backfiring. SO I changed the plugs (thinking that was the issue), but it didnt fix it.
A mechanic friend of mine beleived it should have been conected at the other end to the intake from the pod filter. So we tried that also, and turned up the boost a little bit ( I want to try to get it to about 13psi) I am running the standard turbo, with a big intercooler and an APEXI AFC computer.
Now it is backfiring even worse and we cant seem to ajust the boost at all. Im not sure if the controllers we have (we have two) are faulty or if they are plumbed incorrectly.
The backfire issue we beleive is the coils now, so im going to try sealing them up or change them.
But still unable to really adjust the boost at all,
Has anyone else had a similar issue ?
Does anyone know the Correct way to run the manual boost controler (from the waste gate to the intake pipe to the turbo is how we beleive) Is there anywhere I can get a diagram of this ?
And last but not least ( I am new to this so I have a few issues, thanks to everyone reading this) ,
I live in Sydney, Where would be the best place to take my car to have it tuned, someone who knows allot about APEXI AFC settings?
I have the standard computer in it, and feel this may also be part of my problem, but it should still be able to cope with the mods shouldnt it ?
Thanks Heaps,
Dave
you plumb it from the wastegate actuator to the pressure side of the intake system. so between the turbo and the intake plenum/manifold. not the intake pipe at the pod filter. there should be a nipple for it on the elbow on the turbos outfeed.
and you will be ok with the stock ecu and the mods you have. even better if you get the afc tuned.
Edited by QWK32
Thanks mate, it was set up that way, I still have alot to learn. I changed the plugs and that didnt fix the backfire, so I taped up the coils and it made a big difference, gonna get some new ones soon. Getting the AFC tuned too, that should get me movin!
    • Big single, and seqy. #sorted
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 😛
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
