Clutch Squeak
EARMUFF
 Share
If i listen hard for it, i can hear it. Also, wen i hear the squeak, i can feel it on the pedal, if you know wat i mean. Where abouts is the pivot ball i grease up? Im new to this ay.
Edited by EARMUFF
A user posted up a picture a while back as to where to look and to grease up. I have attached the pic to this response hope it helps.
From what ive been told you need to lubricate the clutch fork itself and within the rubber bit you can stick your finger through. Not too sure what is behind the rubber bit and whether it would do damage to any parts by going crazy with some lubricant in there.
Also try using something like Motorcycle chain lubricant instead of WD40 as it will last longer.
Edited by LatinR33
yeah thats it ^^^^. its about 120-130mm in from the end of the clutch fork, so you should be able to reach it easily. i wouldn't go too crazy with the grease in there. you don't want to get it all over the clutch itself.
Mines does it a little bit too.. Sometimes it make the noise, sometimes it doesnt... >< .
I well try and fix it with this.. if it doesnt work, ill take another look when i change the clutch..
I have an exedy heavy duty clutch! just recently when i press the clutch pedal n release u can hear a bit of a squeak. i'll grease it up n let u noe ;)
Glad you fixed it.
Squeaking is also common when putting in HD cluthes/pplates. The extra force to disengage the clutch actually starts fatiguing the pedal box quite quickly and it starts to flex and crack - squeak, squeak
Hey guys, I have a similar problem as well.
If I'm reading this thread correct, in the spot where you can 'stick your finger through', is that where I should be putting a small amount of grease?
Cheers.
Cheers.
if you stick you finger in that spot and keep pushing it in further you will feel the pivot ball. thats what you want to grease. you may be able to work it out from this pic
http://www.automotivearticles.com/uploads/clutch__3_.jpg
  • 3 weeks later...
 Share
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
    • those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
    • Freshly built stroked RB25/28. Motor runs great but consumes a lot more oil then It should. This summer with the heat I was consuming roughly a quart per 1800-2000kms. Now with the cold weather coming in, I'm consuming a quart per 1000kms which is no bueno. I had originally chalked this out to break in taking a little longer then it should, but I'm now around 4000km's on this engine. I think it's fair to say something isn't quite right. Here's the kicker, can't find what's causing it. I've also spoken to my engine builder and Precision Turbo and can't figure it out. Here's my train of thought on possible causes and what I've done.  Precision Turbo - I originally started thinking my oil pressure might be a tad too high for my 6466 Gen2. I took the center cartridge out, and while yes there's signs of oil on the turbine heatshield, it's very moderate. There's also very minor in/out play that concerns me. I sent pictures and videos to precision and they said the residue and in/out play is minimal and they doubt this is the issue. For piece of mind, I went ahead and installed a Turbosmart OPR V2 to bring oil pressure down. Made no difference. Precision is willing to take it in on RMA for an inspection and I'll probably take them up on that offer for peace of mind. BTW. Is it just me or does the turbines inducer's look clipped and not even between each other? I just noticed this now while posting and looking at the picture zoomed in. Might just be the picture...  Rings - Hot compression test and leak down test look good. Compression is 160 +-2psi across the board. I leak down at 16% on cyl 1,2,3,5,6 and 18% on cyl4. Keep in mind I have a snap on leak down tester and they read high (I.E, 15% on my wifes 2018 Sentra with 70000kms). Sparkplugs show minimal oil (Only #4 seems to have a tad). At a quart per 1000km's though, I would be expecting them to be wet. Here's the kicker, I run WMI. I'm thinking what if my compression rings are great, but I have an oil control ring issue on cyl4 and my WMI is steam cleaning the pistons and sparkplugs? I can still see the "Spool" logo on top of my CP pistons. The only time I see smoke out of the exhaust is in the high rpm/load range. So far, this is my main culprit. I'll probably turn off my WMI and go out with the car at spring pressure tomorrow and repull the plugs. Other thing that's strange though is that I have never seen any oil in my catch can. Thing is still dry after 4000kms. Cyl1 - Left, Cyl6 - Right. Valve seals - They're new and I would expect oil consumption on idle, first cold start or during decel. None of which is happening.  Crankcase pressure - I have 2x 10an valve cover lines to a vented catch can. Head drain and opened up internal oil drain paths. I also don't run E85. I've never seen any oil in my catch can. Doubtful this is causing any issues.  Rear main seal - I have no visible leaks, but figured maybe it was my rear main seal. After now having added 2-3 quarts, I would expect oil to leak out the bottom drain channel and/or my clutch to be slipping.  Let me know your thoughts. With winter coming and taking the car off the road until spring, I'm fine with pulling the motor apart but I would hate to take it all apart and the turbo was the issue in the end.
