I now have my stealth kit but am having major issues putting it on, everything seems to be out by about an inch, I don't know whether I've been sent the wrong kit or the welding on it is buggered but it's got me shitted off haha.
So I was wondering if anyone out there who has fitted one to a S1 R33 GT-ST has any pics of it mounted with the front spoiler off or even just it sitting behind the front bar, it would be awesome, thanks in advance if anyone does.
Or if there are any pointers out there anything would help. Saying 'don't buy a cooling pro' does *not* help the situation btw (even though I'm sort of leaning towards that).
https://www.sau.com.au/forums/topic/215678-issues-with-cooling-pro-stealth-kit/
i fitted a cooling pro kit on mine. not the stealth kit. a hybrid copy, tube and fin, with trust style elongated end tanks.
i had to mix and match brackets, and basically make the thing fit. no way the standard fittings were going to work.
i also ended up using a longer silicone joiner in the engine bay where two of the cooler pips were too far apart.
just get creative. it seemed like the guys at JJ chuck a bunch of brackets in there without much thinking going on.
it doesnt look like you've bent the chassis tip either. this will allow you to slope the cooler, bottom side towards the car. it might make things line up.
I bought a Just Jap kit years ago and had the same problem. Ended up having to make new brackets from aluminium to space things out.
Can you move the cooler back further towards the radiator? If not, what is blocking it?
the ac fan is the major thing in the way that wont allow it to swing an further bak towards the radiator
also yours has just the single bracket in the middle on the cooler to hold it up, mine had to and needed to be bolted up to the reo. whats the go here? i think ur one would be easyier to install and if anything hold ur cooler further back...
Worst case remove the pipe and take it to someone who can weld an additional 30mm to it.
Aren't the cooling pro kits a China brand item? I'm seeing alot of victims from cheap china parts lately, the GReddy coolers arent that much dearer...
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
