The closest Autobacs with anything that you'll be interested in is at Tokyo Bay. It's pretty crappy though.
Check out Crystal over in Chiba or Carshop Nagano, located in Aoto...
Nagano is probably easier to get to than Crystal.
Both have many more parts available than Autobacs and are also significantly cheaper.
http://www.carshop-nagano.co.jp/
http://www.c-jpn.com/
https://www.sau.com.au/forums/topic/215692-autobacs/#findComment-3810294
lmao at nagano he he
LOL i'm not from japan, I don't speak any japanese, and I didn't know that shop called carshop nagano wasn't in nagano!! LMAO! err wait.
Anyways, I'm currently in Asakusa how hard would it be to get to either store from here? From what I could see of google maps it's the next river over from where I am.
http://maps.google.co.jp/maps?f=q&hl=e...&iwloc=addr
Edited by Sarumatix
https://www.sau.com.au/forums/topic/215692-autobacs/#findComment-3814609
Well now you do! :)
http://www.c-jpn.com/shopguide/index.htm
376-5 sonnou-cho,inage-ku,chiba city,chiba,japan.
tel:81-43-256-1331
From Tokyo station they need to take the "Sobu Line" to Chiba Station, then from Chiba Station they need to catch the Chibatoshi-Monorail to a station called "Sports-Center", then walk north past Maccas and a toyota dealer and it should be on the left!
https://www.sau.com.au/forums/topic/215692-autobacs/#findComment-3822861
Definitely check out Crystal. It's about a 10 minute walk from Sports Center, and very much worth it :)
One thing to remember, when you're grabbing things left, right and centre off the shelves, is that you have to carry all your purchases during your walk BACK to the station :(
https://www.sau.com.au/forums/topic/215692-autobacs/#findComment-3822868
Well now you do! :)
tel:81-43-256-1331
you are a champion dude!
gonne be at D1 tomorrow? :( bus wont get there till 9 but I'll be there! Also how much money should I bring for 2 people catching the bus from kawaguchiko
Edited by Sarumatix
https://www.sau.com.au/forums/topic/215692-autobacs/#findComment-3822870
http://www.japan-guide.com/e/e6390.html
I am not sure if there is a bus from there, I know there are buses from Gotemba (610yen) and Suruga-Oyama (570yen) or the taxi for about 3,500yen.
There are tickets on the gate but it is probably worth going to Lawsons convenientce store and getting tickets from there, using the ticket machine things they have. 99% you will need one for Sunday.
L Lawson Ticket code:
Saturday's code 31280 (1,500yen) 2,000yen at the gate
Sunday's code 31290 (2,300yen) 3,300yen at the gate
p.s. Unfortunately I have to work tomorrow so no D1 for me, also it is pretty far from Osaka. I might go to Suzuka.
Edited by dr1ft.jp
https://www.sau.com.au/forums/topic/215692-autobacs/#findComment-3822901
Can someone tell me the best place in Japan to find a set of floor mats like these for my dr30?
http://page3.auctions.yahoo.co.jp/jp/aucti...bluege_web_shop
The best place is Tanigawaya shop in Mie 三重県鈴鹿市神戸3-11-7 [〒513-0801]
Karo R30 "Wooly" floor mats
But there is a lead time on orders so in all honesty it would be better to get someone to order them.
Edited by dr1ft.jp
https://www.sau.com.au/forums/topic/215692-autobacs/#findComment-3851249
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
    • @Dose Pipe Sutututu I read your replies RE: R35 GTR MAFs, any ideal spots to put on? Obviously will need the adapter plate. Will be having a cross over intercooler fitted shortly, would putting it a bit before the TB be okay?
