The closest Autobacs with anything that you'll be interested in is at Tokyo Bay. It's pretty crappy though.
Check out Crystal over in Chiba or Carshop Nagano, located in Aoto...
Nagano is probably easier to get to than Crystal.
Both have many more parts available than Autobacs and are also significantly cheaper.
http://www.carshop-nagano.co.jp/
http://www.c-jpn.com/
https://www.sau.com.au/forums/topic/215692-autobacs/#findComment-3810294
lmao at nagano he he
LOL i'm not from japan, I don't speak any japanese, and I didn't know that shop called carshop nagano wasn't in nagano!! LMAO! err wait.
Anyways, I'm currently in Asakusa how hard would it be to get to either store from here? From what I could see of google maps it's the next river over from where I am.
http://maps.google.co.jp/maps?f=q&hl=e...&iwloc=addr
Edited by Sarumatix
https://www.sau.com.au/forums/topic/215692-autobacs/#findComment-3814609
Well now you do! :)
http://www.c-jpn.com/shopguide/index.htm
376-5 sonnou-cho,inage-ku,chiba city,chiba,japan.
tel:81-43-256-1331
From Tokyo station they need to take the "Sobu Line" to Chiba Station, then from Chiba Station they need to catch the Chibatoshi-Monorail to a station called "Sports-Center", then walk north past Maccas and a toyota dealer and it should be on the left!
https://www.sau.com.au/forums/topic/215692-autobacs/#findComment-3822861
Definitely check out Crystal. It's about a 10 minute walk from Sports Center, and very much worth it :)
One thing to remember, when you're grabbing things left, right and centre off the shelves, is that you have to carry all your purchases during your walk BACK to the station :(
https://www.sau.com.au/forums/topic/215692-autobacs/#findComment-3822868
Well now you do! :)
tel:81-43-256-1331
you are a champion dude!
gonne be at D1 tomorrow? :( bus wont get there till 9 but I'll be there! Also how much money should I bring for 2 people catching the bus from kawaguchiko
Edited by Sarumatix
https://www.sau.com.au/forums/topic/215692-autobacs/#findComment-3822870
http://www.japan-guide.com/e/e6390.html
I am not sure if there is a bus from there, I know there are buses from Gotemba (610yen) and Suruga-Oyama (570yen) or the taxi for about 3,500yen.
There are tickets on the gate but it is probably worth going to Lawsons convenientce store and getting tickets from there, using the ticket machine things they have. 99% you will need one for Sunday.
L Lawson Ticket code:
Saturday's code 31280 (1,500yen) 2,000yen at the gate
Sunday's code 31290 (2,300yen) 3,300yen at the gate
p.s. Unfortunately I have to work tomorrow so no D1 for me, also it is pretty far from Osaka. I might go to Suzuka.
Edited by dr1ft.jp
https://www.sau.com.au/forums/topic/215692-autobacs/#findComment-3822901
Can someone tell me the best place in Japan to find a set of floor mats like these for my dr30?
http://page3.auctions.yahoo.co.jp/jp/aucti...bluege_web_shop
The best place is Tanigawaya shop in Mie 三重県鈴鹿市神戸3-11-7 [〒513-0801]
Karo R30 "Wooly" floor mats
But there is a lead time on orders so in all honesty it would be better to get someone to order them.
Edited by dr1ft.jp
https://www.sau.com.au/forums/topic/215692-autobacs/#findComment-3851249
    • Curious to why you're not getting Jesse to do the exhaust, seeing that he has just done 2 GTRs with Aes valves.
    • What extra parts are you thinking you'll need to run e85 compared to e30?
    • I'm not aware of e30 in Australia, but I'm pretty sure e85 is still around. You really want a setup with an ethanol sensor so you can run any mix of ethanol depending on what you can access. Fuel Check NSW app shows 14 site in sydney metro with e85. What are you adding, will you put in bigger turbs too? Apparently the wastegates are pretty small and can't bypass enough as you run more boost.  I'm sticking to 1.3 bar with 98 on the standard turbos with my tune on advice from the tuner, and boost drops significantly in the top end; apparently larger turbos with larger wastegates are needed to get anywhere meaningful from there.
    • Amazing work Duncan! It is never easy to pick up someone elses project and work all the parts out that are missing
    • Hey Ppl,   I am about to tuned my Infiniti Q60 with E-85 and if you can tell me some location where I can top up my car that would be great.   But my other question, is E-30 available because this tuned requires less mods parts and any info you can offer would be greatly appreciated too!!
