hey guys have just finished doing a neo conversion on an r31 passage. all I have left is to wire up the tacho, apparently the r33 way of wiring it up doesnt work so just wondering if anyone has any definate ways of wiring it up??
cheers Ryan
Hey Ryan
There is a guy in the R31 Skyline club called Kevin Rowley who has done exactly the same conversion as you into his coupe. In fact its one of the hottest coupes around in yellow with volks including semi auto shift on the steering wheel. I dont have a contact number but he can be reached on the R31 forum (www.r31skylineclub.com profile name Neo31), his email is [email protected] and lives at Bellbird Park.
Regards, Andrew
Hey Ryan
Regards, Andrew
cheers mate i know exactily what car you are talking about but unfortunately he is also using the r34 dash cluster so making his gauges work would have been easy but im still using the stock r31 gauges.
cheers Ryan
cheers Ryan
I would still make contact with him as he is an auto electrician. He is very well known for all things technical and specialises in work on cars with non-standard mods such as your upgrade. He is also a very nice bloke and as a fellow enthusist he will look after you. Good luck.
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
