sweet, came up looking pretty good, did u run into any hassles whilst doin it? and what type of cooler is it? im going to get a blitz lm kit when i get my lazy arse round to doing it.
Greddy kit.
It was all pretty straight forward, fair bit of grinding involved.
nice... not being rude..
but did u need the FMIC??
Running 9psi with a stock turbo at the moment, so not really.
But I'll be doing a fair bit of upgrading in the next 6 months, so it was the first step.
how much REO is left?
More than half :blink:
https://www.sau.com.au/forums/topic/215723-finally/#findComment-3811453
i wish i had installed my FMIC, and not a performance joint.
they had grinded my vicious fan so that the intercooler pipe wouldn't hit it
they had the intercooler pipe resting against the radiator hose.
also had my intercooler bracketed to my headlights, which over time snapped my brackets, and also from the viabration snapped my air condenser alloy pipe
Farkin wankers.
Anyway good job, looks good.
https://www.sau.com.au/forums/topic/215723-finally/#findComment-3815454
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
