What turbos are you 350+HP guys running (rb25)
i dont want to use HKS since its SOOOOO expensive.
so im open to other turbos, any ideas?
i have all supporting mods now, and just need turbo, then i can do ECU retune.
i need powaaaaaaaa
I blew my rb25 turbo, and i have a rb20 turbo on it now as a spare, and its killllling me
https://www.sau.com.au/forums/topic/215747-turbo-help/
bush bearing (360-degree not 270) high flow Rb 25 turbo, with oil and water cooling
steel wheels
front / rear housings bored to the max
under a grand new and fitted :D
Where from? PM me.
https://www.sau.com.au/forums/topic/215747-turbo-help/#findComment-3811107
lol, cant help with what I have (Slide Performance hiflow) as they arnt made anymore
arnt there turbo places in Japan that do highflows?
there are at least 2 well known turbo shops in each Aussie state that can do either journal or bb high flows...... but you wont find anything close to the cost of the $790 one I have :D
I would have thought you could pick up a 5000km old hks 2535 for a grand in japan. yahoo auctions and all that
https://www.sau.com.au/forums/topic/215747-turbo-help/#findComment-3811115
there are at least 2 well known turbo shops in each Aussie state that can do either journal or bb high flows...... but you wont find anything close to the cost of the $790 one I have :blink:
Then gimme yours! :)
https://www.sau.com.au/forums/topic/215747-turbo-help/#findComment-3811281
i can
but not a 400HP turbo
i can pick up the 2535/2540 for around 5 or 600 (i have one) but that wont get me up and over 350 supposedly
im looking for bigger numbers
https://www.sau.com.au/forums/topic/215747-turbo-help/#findComment-3811362
how much are they charging for HKS GT-RS kits there? it should be reasonable money.
nengun should be able to get it to you for around AUD$2k (bolt in kit). alternatively what about a GT3071 (60mm turbine, 56 trim comp) should be 450hp turbo but some fiddling around with dumps, spacers (maybe) and braided lines. it depends on availability in japan. failing that atpturbo.com seem to be reasonable for prices and delivery.
plus if you can pick up a HKS cast manifold on the cheap as they have a divider you could even buy the split turbine housing to go with it which should spool up even quicker. lots of options out there.
how much is too much to spend?
quick edit: greenline have the GT-RS for 222,500 yen.
Edited by wolverine
https://www.sau.com.au/forums/topic/215747-turbo-help/#findComment-3812279
which is way to much
im looking under 1500 for turbo only
G`day Grant,HIFLOW`S $1750 & that cheap i have been quoted more one place wanted $2000,so look`s like you might be looking around of one your end haven`t seen many in aussie for sale.i have a HIFLOW which is buggered had quote to fix $1200.hope you find somethink.cheer`s chuckie.
https://www.sau.com.au/forums/topic/215747-turbo-help/#findComment-3812358
I got an awesome deal from slide.
seven hundry + two buggered turbos (1x 32, 1x33) got me a 33 highflowed in return
with injectors (got 550's sitting here) and ecu remap (one day this year) Id expect 220awkw without leaning on it too hard.......
https://www.sau.com.au/forums/topic/215747-turbo-help/#findComment-3812396
I have a brand new Garrett 3076R for sale. It cost me $2100 AUD
You can have it for $1500AUD + shipping to JP (probs $100)
Details/photos -> http://www.nissansilvia.com/forums/index.p...howtopic=277649
Will suit your drifting application perfectly seeing it was designed for a 2L and is rated to 525hp....In fact my friend has the same turbo on his R33 GTSt and makes 290rwkw.
T3 flange and externally gated (the only proper way to be gated)
Edited by AlexCim
https://www.sau.com.au/forums/topic/215747-turbo-help/#findComment-3814914
BUY IT
2530 should do 220rwkw?
https://www.sau.com.au/forums/topic/215747-turbo-help/#findComment-3815169
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
    • Glad it eventually came out Duncan!   I believe that might be 040. 044 is the inline pump, so has screw fittings in and out. 040 is more just drop it in fuel and the bottom is "open" (mesh) from my memory
