Who's Got The Best Looking N/a Here?
Guest IH8VEE8S
no its actually alot better. the alluminium v8 is 60kg ligter than the rb, and it sits alot further back.
im running the t56 tremec 6 speed box with a lightened jim berry flywheel and solid ceramic clutch.
there is a build thread in the projects section.
yeah, thats tuff.
Does it throw our weight distributions and balance out the window?
What box you running?
  • 3 weeks later...
Hey guys!
Im from New Zealand.
Im new to this website.
I just got a skyline 2weeks ago or so, so here are some pictures
From my understanding its R33 rb25de GT, please do correct me if i have left anything out or got something wrong.
This is my first decent car, my old one was ford telstar 1989 :).
Weird aswel does all skylines this year have battery in boot, mine is.
Cant wait to read more forums and chat with some more aussies :P
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
