This is my mates R34 GT, rolling on Superlaps.
Its one of the best looking 34's around let alone the best looking N/A, in my opinion anyway.
  • 3 weeks later...
that car gives me a rock hard boner.
wheel specs?
loose the I'm a wanker sticker from the windshield and grab some jap wheels and it would be great.
also imho, the bonnet is a bit naff, given not much heat comes from a 25DE engine bay
I will be taking off the "I'm a wanker sticker" as you put it . so many ppl hate on it . . you would hate to see whats on the rear window then lol
Edited by joker's r34
whats on the rear window lol?
(hey man cant be any worse then mine, we got some mates together and got some small stick on vinyls made up and we all get around with them stuck to our cars rear windows, its fully fast and furrious team spec ;P)
You got the same bonnet add on as i got on mine
Worked RB26/30DE underneath that does get warm
What's under yours/ going under yours in future?
Hey dude is your bonnet cut in or just moulded on top ? . Looks done well tho I must say
I'll post a pic up tonight of my rear window and my "AWESOME" sticker
we should start a (who's got the worst sticker on there N/a page ^ ^)
LOL
Happy ? :)
LOL
Hahaa, dude thats not that bad. pretty witty lol :P.
weve got a small vinyl sticker that i designed then we each put TOP GUN nicknames with them, im not even kidding, we've got Maverick Iceman Wolfman Slyder and Jester atm LOL :P
(if you have an NA skyline you've gota have a sence of humor)
http://www.facebook.com/home.php#!/photo.php?fbid=10150281244601363&set=t.607876362&type=1&theater
(Thats a pic of the iceman one on a mates XR6t, hope the link works lol) *we're getting off topic, back to the NA 'lines
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
    • I am being real ocd and do not want to make amy mistakes so appreciate all help provided. I am overly cautious so asking for opinion even if i know the answer   few questions,   1.re tensioner, should spring be greased lightly?    2.tensioner has two washers , one pressure washer and other has recessed/ seat. I am going to put the recessed one facing tensioner where edges are cut out and pressure washer on top   3. my car has custom triger kit sold few years ago by guy who initially built the engine. I moved the crank gear and it moved in and out easy, only way to remove belt is to slide the crankshaft gear forward which I did. I have seen these being very tough to move , anything to do with my woodruff key?   it has a crank sensor shown in purple which I assume reads from the 12 teeth position mounted to the crankcase gear   4. timing belt doesn’t have arrow stating front or back just a arrow which I think is direction of rotation . Do you agree?   5.i figured out why my crankcase cover was worn as there was no washer installed over the crankcase cover before the harmonic balancer was put in place. It is missing, anyone knows the part number? It looks like this https://justjap.com/products/genuine-nissan-crankshaft-timing-gear-rear-plate-washer-nissan-s13-ca18-a31-r32-rb20-r33-r34-c33-c34-c35-rb25?currency=USD   https://tinypic.host/image/IMG-4535.382Zy2 https://tinypic.host/image/IMG-4537.382dSz https://tinypic.host/image/IMG-4534.382q4U
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
