hey man nah havent lowered it :s ..i thought it looked like it tho in the pics
made 101kw :s thought id atleast get 110kw..i duno tho...i havent had 100k service done n im well past due for it..117k
but yeaa :s i needa get a CAI happening, cause i just have a pod in a box atm.
whats mods you got 123kw fair amount for a n/a.
yeahhh autoo lol
Is that all? just a pod no exhaust? If so 101 probably isn't too bad..pretty sure they make around 91 stock standard... oh and i'd be getting that 100k service done...a busted timing belt can be pretty nasty, prevention is better than cure, unless you want an excuse to do a rebuild :P
101 is good man its just that mines manual i think gets a bit more power to the wheels
i just had a pod in no box or anything (lazy) and catback exhaust
pods off now though got defected for it not being secured properly
Yeah when i first dynoed mine it was running like shit, spark plugs/coilpacks on their way out and being an auto it only pulled like 95rwkw lol
havent dynoed it since but i expect it to be much better :ermm:
  N-DAWG said:
Is that all? just a pod no exhaust? If so 101 probably isn't too bad..pretty sure they make around 91 stock standard... oh and i'd be getting that 100k service done...a busted timing belt can be pretty nasty, prevention is better than cure, unless you want an excuse to do a rebuild :ermm:
ey i got pod in a box, extractors and 2.5 inch exhaustt with cannon on the back
hopefully once i get 100k service done it might run like it should which im hoping is better, what sort of parts could be affecting its actual performance, anyone know what price range is on a 100k service?
Have a grand ready for the 100k service. They replace the water pump, timing belt, and the other usual stuff. It's the labour involved in such a service. Still though, the cost of a 100k service is nothing compared to that of a snapped belt resulting in anything from bent valves and other expensive engine repair.
When I bought my R34 I was told that the timing belt had been replaced already. I didn't take the chance, got it changed, and sure enough it was the original very worn factory timing belt. Make sure you get the idler and tensioner pulleys as well as seals.
Anything can affect the performance really, from spark plugs, to coil packs, the fuel used, the cat could be holding it back due to age, air filter might need cleaning...a lot of variables really.
What fuel do you use?
Also keep in mind not all Dyno's will report the same. I've known of some cars to read out anywhere from 10-20kw different between dynos. You should always use the same Dyno when measuring performance between modifications if you're wanting to see the comparison.
nathan is spot on there, had the 100,000 done on my 33, cost just over a grand. water pump replacement is optional fyi, i opted to get it done thoe as they tend to show their age as they approach the 100,000 mark. well worth it.
get nissan to put their full synthetic oil in it too, unless you wanna use your own. apparently its good, costs $40 for 5L (got a quote today)
I try to time my services with major upgrades =] My last service coincided with my conversion, works out bit more worthwhile then.
Check out some of the sponsors, I know there's some that do the 100k service drive-in-drive-out quoted parts supplied. I done mine when I was still relatively new to Queensland and ended up getting a mechanic referred to by work mates to do mine. Got my timing belt kit from CRD (Croydon Racing Developments). My mechanic said my water pump still looked good till probably 150-180,000 kms at which point I'd might as well do the timing belt again. By the time I get to that sort of mileage (I've done under 10,000 in the last year) I'll be ready to take performance to another level and do a rebuild anyways, so I didn't worry about the water pump at that stage particularly when cash flow for me wasn't at its best.
If you're looking to get adjustable cam gears, that's a good time to do it since the cam cover and belt is off and they're changing the seals. I wish I'd tried to squeeze in an adjustable exhaust cam gear back then, would have allowed for a bit more fine tuning.
Edited by N-DAWG
  • 2 months later...
