My R33 GTS25
(sorry i tried to put in a pic, dont know how)
upgraded racing suspension, pirelli tyres, rodney jane 17s, rear sway bar and a sound system with a 12" JL audio sub
Edited by mick2nv
My R33 GTS25
www.photobucket.com upload the images there, resize to suit the average screen size, and copy and paste the code, and done :)
Very nice! Very clean and tidy ride :) Some subtle sideskirts and rear corner extensions would complete it nicely
thanks mate! not as much mods as your r34 though lol
im getting a catback exhaust today yeahhh!
hey everything in good time :down: I done everything else besides power mods first, and picked up the car from my tuner after the conversion, exactly a year after I'd originally purchased it in its stock form. You've done the right thing going for suspension, sway bars and wheels/tyres first, the best thing you can do to any car really.
Great photos!
How did the rest of the day go? ..shame about the long waits between short track stints..
I struggled a little throughout the day with the lack of power.. I kept trying to go in 3rd gear..
Love this body kit ! Would look mad with tinted windows and the right set of wheels :banana:
Thank you. Was looking @ rp03s & some other but haven't decided yet. Half way thru tinted windows, rear of car were already tinted when I bought it. :rofl:
My n/a R32
Engine: RB25DE
Suspension: Konie springs
Mods: Splitfire coilpacks
apexi pod filter
full 2.5 inch cat back exhaust with 3.5inch tip
Ganador mirrors
HID headlights (extreme white, blue parkers)
probs some other things... ill update later with more photos :) what u think?
Edited by r32na
My n/a R32
Engine: RB25DE
apexi pod filter
Ganador mirrors
Hey, your car looks really nice and clean.. loving the no spoiler. :angry:
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
