  • 1 month later...
Just need some coilovers... then mines not too bad :P Also waiting for my GTR spoiler to get painted and fitted.
More pics can be found here
Looks nice.. Your car is virtually the same as mine now - Same front bar, skirts, same coloured wheels.. Same mods and then me waiting on coils/springs too lol
Cheers Greg,
After a bit of research i learned it was a full top secret kit minus the front quarters with the vents. Its now got Tein Super Street Coilovers, Carbon Intake Pipe, Jim Wolf Popcharger and heatshield, Stainless Extractors and Johnny Spec Twin 2 1/2" mandrel bent zorst with highflow cats and x pipe.
Unfortunately Some lovely fu(k keyed it last week so its booked into the body shop to get the entire passenger side and front bar resprayed... Was so close to having a enough money to order some 20's for it and now this... iggnorant pricks... ah well... ill post some more pics tonight
hey thanks Greg
she is definatly starting to look good................now to make her go a bit faster........gonna be doing some engine work next year aiming to (hopefully) get close on 200 kW at the wheels
with no turbo, supercharger or nos :(
Heres a couple more, looking at some dress 20's for it but next mod will be a kazz 2 way.
Believe it or not were considering a VK56 swap for it... same reason we did blacky originally, the current engine/gearbox combo is worth alot of money here in aus, id import the titan engine and another vq 6 speed manual and adapt it... just researching atm... but its looking good ;)
Hehe yeah.. I ran a 14.32@98MPH with all the mods but with the stock airbox... Pretty sure its quicker with the stock airbox over the pod... But for the time being the pod stays as it gets rid of some of the horrid twin cam resonance it has, putting some extra resonators and expansion chambers in the exhaust over the weekend to hopefully fix that. Its plenty quick enough, but it would just be damn cool a V8, especially the VK56.
ill have to get some 560GT badges made up just to confuse people if and or when i do it :)
marios r33 is f**ken shhhmick! +10 votes for you
i love the white r33's even if there are alot of them around, my old stacked 33 was white my new one is grey....i like white better =/
where did you get your interior done? could you post some more pics of the interior? cheers
thanks man, at least i got a fan haha
ive changed the car a fair bit thou, lowered it more, added the rest of the kit etc, looking shmick
a mate in sydney dun it
im tryin to sell the interior now so hopeing sumone buys its
i will get sum shots up of the trim thou
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
