  • 4 weeks later...
  • Replies 79
Posted Images
  • 1 month later...
  • 3 months later...
  • 2 months later...
Hi there fellow members,
Can anyone please tell me what the person above is doing with that blue light lol, I have no idea :)
maybe checking for leaking brake fluid ?
does brake fluid fluoresce under UV light ?
either that or looking at the brakes using a cheap multi 5mm LED light (which will show up as hell blue under tungsten light, or even flash, the shadows and hotspots on the image look like the flash was above and right of the lens, like a P+S flash but it was shot with a Sony A200)
anyway, heres one of mine of Steve, 200m into the first stage
and Peter Major, last corner of the last stage
Edited by Echo63
https://www.sau.com.au/forums/topic/215750-r35-gtrs/page/4/#findComment-5443313
  • 3 weeks later...
  • 1 year later...
  • 1 month later...
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
