Make: 96' Nissan Skyline GTS25T
Milage: 85,000km
Transmission: 5 speed
Colour: Grey Silver
Complied? Yes
RWC supplied? Yes
Currently registered? Till Feb 09
Price: $16,000neg
Contact: Via Pm or 0410 687 984
Comments / Modifications:
This has all been done by Matt @ BEL...........
**Tube & Fin Front Mount Intercooler
**Garrett 3076 only done 2000km
**Ems 8860 ( this is one best Aftermarket computer going around Now)
**Os Giken Twin Plate clutch
**Greddy profec B sepc II
**Tial Wastegate 38mm
**Nismo 740cc injectors
**Walbro Fuel Pump
**Sard Fuel Reg
**D1 spec Catch can
**K&N pod with custom box
**Liverpool exhaust Custom 3" mendrel bend exhaust.
**Spitfire Coils
This car is a dream to drive. Standard internals Running still at 157comp on all.
9psi = 220rwkw
14psi = 250rwkw
17psi = 271rwkw
https://www.sau.com.au/forums/topic/215787-96-nissan-skyline-gts25t-271rwkw/
  • Replies 40
Well hopefully some will be intrested in 16
Had no luck...................
I am in no rush man ...... if it goes then it goes
  • 4 weeks later...
16k!!
Give it some time and the right person will come along!! Just gotta be patient.
But then again 33 market is flooded and the prices are dropping like crazy :)
Edited by siddr20
I agree with siddr20, even if you wanted 13 thousand you'd still be somewhat hard pressed, but when people see a modified 12 year old car then it's going to be hard, is the car on carsales.com?
nah what i meant was.. keep it at 16k.. dont bring it down further!!
its such a tasetful car with some really nice mods :teehee: someone will appriceate it and buy it!!
gdluck
do you pay more for the plates each year? what gauges are mounted on the b-pillar? did the ems plug in? does it need any type of engineer cert for anything / could you be defected for anything? bov?
    • The prices I’ve heard aren’t that bad
    • Oh, I also meant to say that it is possible to use a venting BOV and restrict its outlet down so that it does vent enough to prevent the sututu, but vents slowly enough that the AFM doesn't see all the air at once and makes it easier to avoid stalling.
    • I'll go talk to my bank manager. Either that or my nearest western Sydney drug baron.
    • Driveability will be about the same with either externally venting BOV, or no BOV at all. Perhaps worse one way than the other, with me thinking that the definitely more flow going through the AFM through a venting BOV more likely to cause rich stalls than the perhaps more flow that the AFM might read on reversion. There is no such thing as "turbo damage" from not having a BOV at stock, or even quite a lot higher than stock, power levels. You need a big turbo with a lot of mass spinning hard getting a horrible slowdown from a slammed shut throttle before there is anything like the shaft loads required to damage things. Not an issue on small turbos. The ONLY 2 reasons that Nissan put a recirc valve onto the RB were: It is a bypass valve. It is open when under vacuum. When not on boost, it bypasses intake air forward around the compressor, which unloads the compressor, allowing the turbine to sping more freely, making the whole lot a bit more efficient when just puddling around. Throttle response should also be faster via the shorter, smaller diameter BOV pipe (when in NA, ie before the BOV closes and boost is building) which is nicer for driveability. Emissions. The reversion causes CO pulses. Eliminate the reversion (or at least, keep it away from the AFM) and you don't get that. The stalling/driveability aspect could have been tuned around, as shown one example of by dose above, if Nissan hadn't put a recirc valve on. Many many turbo engines before the RB had no BOV. They did not stall. See the RB30 turbo as an example. Nistune is definitely better than just stock ECU. It allows you to access and change things that are not excellent on the stock setup, and allows you to do mods like put decent injectors in, relocate the AFM, put a bigger turbo or even cams, etc, on, change to coil swith completely different swell needs, etc etc. All the things that you might need or want to do 25 years after the car was new. Aftermarket replacement ECU is obviously better again, because it gives you even more freedom from the constraints of the stock ECU. I won't be needing to go any further than Nistune though, for the new turbo in the 250ish rwkW region I'm going to, with big injectors, and most other things being stockish.
    • Lucky the prp block is supposed to be released next weekend
