hey guys, i am suspecting a block posibly of my return line for my fuel and hence high pressure. i have nismo 555cc injectors and a stock FPR and a GTR pump in my R33 GTST. running power fc with 66.5% correction and 0.18ms lag correction. on idle my car is running at like 9 afr!!! you can just smell the fuel for days but then when she is driving it all seems to be fine, but still a little too rich for my liking...
is there a way of checking the fuel pressure short of buying a guage? or at least checking if the return line has a small blockage and hence increasing the pressure?
https://www.sau.com.au/forums/topic/215813-testing-fuel-pressure/
well then i will buy a gauge....thats not the answer i was looking for...thats the easy option...
well theres a way to test the return line
try to blow down it
or to clean to blow compressed air down it,
sorry but there isnt! unless you know someone with one, there is no other way to get a reading.
Blocked return line would normally cause a ramped effect with the AFR's since at idle the std earthing reduces the voltage at the pump to slow down flow - so it would get worse as it revs up.
ok so i have blown out the lines with an air gun. the send line seemed to be clear but a whole lotta gunk came out of the return line, may have been caught in the check valve. went to my mechanic to test the fuel pressur and on idle it sits at 2 bar (32psi) is this correct? when it goes on the dyno soon i'll check it right up to 7000rpm...
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
