hey guys, im aware that the vct shares either an earth or power with other sensors like the o2 sensor etc but my VCT isn't clicking and on the hand controller the vct switch doesn't come on and the extm stays on 5.00v and the 02-1 stays on either 0.04v or 0.00v...I had recently installed a Z32, pfc which im pretty sure isn't the cause of the problem because i unplug the afm and wack the standard ecu back in and still nothing. I have added power to the vct solinoid to see if that was the cause but it clicks fine. I can find 12v on the plug however. Car is getting TUNED tuesday next week and i want it to be sweet!
any ideas people?
put the car in gear and clutch pedal in, tap the accel, VCT should turn on
VCT wont engage with the car in neutral
for VCT to engage on the std ECU or the PFC the following must be true;
RPM must be less than 4500rpm (default, adustable on PFC)
NTR must not be active (must not be in neutral)
TPS must be more than 0.0 (which is really around 0.33v ish) - ie; open the throttle a bit
so if the vct is working when in neutral i take it there is a problem so where else in the system??
i will have to do some more investigating on my 25 then.
Usually just the neutral switch in the gearbox not connected/working.....the ECU thinks the car is 'in gear' so VCT is enabled
well after checking my neutral switch and the way my car behaves i realised that the neutral switch is playing up and causing my vct to operate when in neutral . fc hand controller came in handy to tell me if the switch was working and only in some positions was it registering .. now have to find out why is does not work. i quess that having done 200'000 kms plus its well and truly worn out.
  • 2 months later...
Hey guys i have the same problem in that my vct isnt coming on. I reved the car in both neutral and in gear with clutch in and still no clicking noise. My power fc says its not even sending the signal to turn on the vct and so the vct receives no voltage and i have tested this to make sure with a multimeter.
Do u think that my neutral switch could be stuffed the other way, making the car think im always in neutral and so no vct? Also wheres the neutral switch both on the car and on the power fc so i can check?
how are you testing this theory?
drive around in 2nd gear, under 4500rpm and accel a bit
watch ETC, SENSOR SW CHECK
does "VCT" have a black dot next to it?
if so, the PFC is turning the relay on
if VCT doesn't come on - ie: solenoid is shagged etc, the PFC wont know this
as in, as far as the PFC knows, the relay is ON once it has black dot
if the oil line was say unplugged, the PFC wouldnt know this
Thats exactly wat i looked at. there was no black dot next to it. But i just tried it again then and now its working for some reason so very strange but its the first time i have ever heard the car turn the vct on (havent had the power fc long and havent driven it with the new ecu yet). So i put the stock ecu back in and the vct stopped working again. I could tell because the switch was getting no voltage and also the click didnt appear. Why do u think the stock ecu doesnt want to turn the vct on? But the power fc will?
And also i cant drive the car cos front pannels are missing to fix them and i have no licence. I did also notice that when the vct started working - at the same time my idle became really rough and now hesitates and is rough when i accelerate. Why would this be?
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
