hey guys, im aware that the vct shares either an earth or power with other sensors like the o2 sensor etc but my VCT isn't clicking and on the hand controller the vct switch doesn't come on and the extm stays on 5.00v and the 02-1 stays on either 0.04v or 0.00v...I had recently installed a Z32, pfc which im pretty sure isn't the cause of the problem because i unplug the afm and wack the standard ecu back in and still nothing. I have added power to the vct solinoid to see if that was the cause but it clicks fine. I can find 12v on the plug however. Car is getting TUNED tuesday next week and i want it to be sweet!
any ideas people?
put the car in gear and clutch pedal in, tap the accel, VCT should turn on
VCT wont engage with the car in neutral
for VCT to engage on the std ECU or the PFC the following must be true;
RPM must be less than 4500rpm (default, adustable on PFC)
NTR must not be active (must not be in neutral)
TPS must be more than 0.0 (which is really around 0.33v ish) - ie; open the throttle a bit
so if the vct is working when in neutral i take it there is a problem so where else in the system??
i will have to do some more investigating on my 25 then.
Usually just the neutral switch in the gearbox not connected/working.....the ECU thinks the car is 'in gear' so VCT is enabled
well after checking my neutral switch and the way my car behaves i realised that the neutral switch is playing up and causing my vct to operate when in neutral . fc hand controller came in handy to tell me if the switch was working and only in some positions was it registering .. now have to find out why is does not work. i quess that having done 200'000 kms plus its well and truly worn out.
  • 2 months later...
Hey guys i have the same problem in that my vct isnt coming on. I reved the car in both neutral and in gear with clutch in and still no clicking noise. My power fc says its not even sending the signal to turn on the vct and so the vct receives no voltage and i have tested this to make sure with a multimeter.
Do u think that my neutral switch could be stuffed the other way, making the car think im always in neutral and so no vct? Also wheres the neutral switch both on the car and on the power fc so i can check?
how are you testing this theory?
drive around in 2nd gear, under 4500rpm and accel a bit
watch ETC, SENSOR SW CHECK
does "VCT" have a black dot next to it?
if so, the PFC is turning the relay on
if VCT doesn't come on - ie: solenoid is shagged etc, the PFC wont know this
as in, as far as the PFC knows, the relay is ON once it has black dot
if the oil line was say unplugged, the PFC wouldnt know this
Thats exactly wat i looked at. there was no black dot next to it. But i just tried it again then and now its working for some reason so very strange but its the first time i have ever heard the car turn the vct on (havent had the power fc long and havent driven it with the new ecu yet). So i put the stock ecu back in and the vct stopped working again. I could tell because the switch was getting no voltage and also the click didnt appear. Why do u think the stock ecu doesnt want to turn the vct on? But the power fc will?
And also i cant drive the car cos front pannels are missing to fix them and i have no licence. I did also notice that when the vct started working - at the same time my idle became really rough and now hesitates and is rough when i accelerate. Why would this be?
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
