Hey all, I decided to clean out all this stuff in my room. Theres heaps (and i mean heaps of things here). Everything is negotiable. I've put down good cheap prices anyway, so hopefully they all go quickly.
Im happy to post smaller bits at the buyers expense, but big bits (eg.sunroof) will have to have postage organised, coz simply i dont have too much time to fart around like that.
Contact me via:
e-mail/msn. [email protected]
mobile. 0400531138
Im located in Montrose, which is the eastern suburbs, like 40mins from the cbd.
ITEMS.....
R32:
Stock suspension (all 4 springs and shocks, ran like new) Reason for sale being i upgraded to aftermarket lower ones $250
Sound system:
Earthquake 4ch amp 600w RMS (retailed at 700 2 years ago, works fine) $350
Soundstream Tarantula 2ch amp 360w RMS $200
Pioneer 3-way 6x9s in boxes (350w) $100 for two
Heaps of wiring, enough for a decent amp setup, very good quality $50
3x Green neons (plug into ciggy lighter) $30 for all 3
No-name e-bay brand 7in in-dash screen $90 (works fine, just needs the cable, or a good car audio guy can wire it in without the adapter plug)
VDO cd player (sometimes the cd stuffs up at track 7, but great for plugging a mp3 player into!) $40
2x Kenwood 12" subs (i had plans for these, but fell through) $40ea or $60 for both
Sound system (soarer):
All stock speakers (4x4in speakers + stock sub + bracket + stock head unit) $40 for it all
Odd bits:
A'pexi turbo timer + wiring $60
Acer computer case (case only, no internal bits) black and silver. $40
3R Racing pod filter, seen better days, but would work time if you need one desperately. $20
Civil Engineering textbooks (two unopened...lol) $100 for them all (paid like 400 for them)
Steering wheel cover (off a s13 with stock steering wheel) $10
Soarer Parts (off a '91 TT, grey interior, that i wrote off about a year back, this is all i have so dont ask for more)
FULL COMPLETE SUNROOF works fine, very good nick! $100
Parcel-shelf carpeted bit that also covers stock speakers $30
Window motor (passenger side) $20
Passenger side door trim- all complete $60
Drivers side door trim - minus the pocket / arm rest bit $30
Carpeted piece that divides boot to the petrol tank (black) $20
Both driver and passenger side rear "door trims" $30ea
Passenger side window surround $20
Drivers side window surround (broken, but can be glued easily, lol) $5
Rubber door seals $5ea
Fuel flap (dark green) $10
Passenger side door handle (dark green) $15
Under-steering-wheel leather piece (in the pic with the seals) $5
Mirrors (dark green) $30ea
Windscreen wipers (fronts and back + motor) $5 for fronts, $10 for back
Rear Seatbelts $15ea
Sun visors $5ea
Fuse box cover (little handle thing) $2
Another big plastic cover, think its the bit at the passenger's feet to the left $5
Centre interior roof light (comes with sunroof switch) $10
Plastic bit to the lower right of the steering wheel (same pic as above) $5
Door lights (i have 3 + covers) $5 for them all
Complete Glovebox very good condition $30
Door liners (plastic that runs along the bottom) $5 for both
Gear stick surround (automatic) grey bit is snapped, but black bit still in mint condition $15
Lower plastic bit that has bonnet lifter lever on it $15
Rear left tail-light, no scratches, lights still work fine $20
Light grey centre console, includes the box bit, could do with some interior cleaner on it $20
Rear wing/lip thing with brake light. has some scratches from storage, could do with a respray $40
Boot mat (one that folds in convenient spots) VGC. $30
ANY REASONABLE OFFER CONSIDERED, THIS ALL JUST NEEDS TO GO!
Pics are all below.
19042008624.jpg13042008601.jpg13042008602.jpg13042008604.jpg13042008605.jpg13042008606.jpg13042008607.jpg13042008608.jpg13042008609.jpg13042008610.jpg13042008611.jpg13042008612.jpg13042008613.jpg13042008614.jpg13042008615.jpg13042008616.jpg13042008617.jpg19042008623.jpg19042008625.jpg19042008626.jpg19042008627.jpg19042008628.jpg19042008629.jpg19042008630.jpg19042008631.jpg19042008632.jpg19042008633.jpg19042008634.jpg19042008635.jpg19042008636.jpg
Edited by ash-s13
https://www.sau.com.au/forums/topic/215835-ashs-uber-massive-bedroom-cleanout/
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
