Hi all,
I was wondering how much torque NM your r33's have please list mods,
Im just interest in how much a r33 with 160rwkw will have and how much one with 200 rwkw will have, usualy mods used to get to these power levels is assumed.
Ive heard 600nm from a 200rwkw engine is about right?
Any tips suggestions would be great, and if youve been in a v8 compare the torque curve to that of a r33, the incar experience not tech,
Thanks
https://www.sau.com.au/forums/topic/215846-r33-torque/
  • Replies 47
what special dynos are you guys going to? Anything above 450nm on a factory setup is a load of shit
I've been to 3 different dynos, all come out the same. 240rwkw and 480nm torque, and this was with a GT3076 7 blade compressor and cropped turbine.
Two of these dynos now say 314rwkw and 720nm.
213rwkw and 670nm torque
Might want to tell the operator to run his dyno properly. Thats simply a crap reading. You need to be pushing more than 260rwkw to manage that much torque.
f**k I love it how people have no idea
https://www.sau.com.au/forums/topic/215846-r33-torque/#findComment-3813169
R33 GTR stock as a rock besides Trust Power Evo. II exhaust including de-cat pipe also some Jap "power chip" of unknown origin:
- Max torque: 589.5Nm @ 94kmph (in 3rd gear)
(As a reference Max power: 189kW @ 134kmph)
Cheers,
Big Mike
https://www.sau.com.au/forums/topic/215846-r33-torque/#findComment-3813287
all the dynos reading your torque provide the correct graph but the graph may not have the correct readings. So the map of your torque and where it rises, drops etc will be correct, but the reading in NM wont.
Im pretty sure all gearbox ratios, diff ratios etc need to be entered before an accurate torque reading can be had?
I used to own a 5LTR commodore and compared to my R34 GTT it had loads more torque, everywhere. More importantly it had usable torque right from the word go, where as turbo engines generally lack this.
https://www.sau.com.au/forums/topic/215846-r33-torque/#findComment-3813556
Cheers,
Big Mike
Lol definitely over doing it abit. More torque then an R35 GTR? You've got a pretty torquey standard RB26!
Edited by Granthem
https://www.sau.com.au/forums/topic/215846-r33-torque/#findComment-3814197
At 255kw@wheels mine is around 550-600Nm, not sure on actual figure as i dont have the print out of the torque curve only power curve.
Old mans Blow CV8 Monaro was dynoed in Brisbane at Power Torque with 370kw@wheels and 1080Nm of torque, then with a bit of a tidy up of the tune up here in Townsville and changing the air intake slightly its making roughly the same power with 1100Nm of torque. No bullshit on both torque figures, i have both dyno graphs. It feals unreal and plants you in the seat like no other car i have ever been in.
Edited by PM-R33
https://www.sau.com.au/forums/topic/215846-r33-torque/#findComment-3814372
its an older type of dyno and reads proper power not bullshit power like all your typical shootout modes etc and on a new type it would read around 250rwkw so i dont think my nm is wrong , but hey worth having a go :D
Edited by l0WRB
https://www.sau.com.au/forums/topic/215846-r33-torque/#findComment-3814450
and u claim 314rwkw and only 114mph and only 700nm? for starters u dont even have the mph to back up ur aclaimed 314rwkw so id watch what u say about dynos and bullshit figures. :D
https://www.sau.com.au/forums/topic/215846-r33-torque/#findComment-3814459
Go to the place that tuned it and poke smart ass remarks to them. Im going by numbers on the dyno sheet.
Thanks champ.
Big Mike
https://www.sau.com.au/forums/topic/215846-r33-torque/#findComment-3814655
Thanks champ.
Big Mike
Well hopefully the smart ass remark has made you think about it. Do you honestly believe your Rb26 makes more torque then a VR38DETT?
I know you might have a read out, but I would doubt it heavily if I were you
Not harm intended :D
Edited by Granthem
https://www.sau.com.au/forums/topic/215846-r33-torque/#findComment-3814669
Have any of you quoting figures had your cars specific ratios entered before the run?
Or are you claiming the figures that come up when you throw it on a dyno?
Can anyone confirm my belief that the ratios need to be entered to accurately measure torque is correct?
Edited by Granthem
https://www.sau.com.au/forums/topic/215846-r33-torque/#findComment-3814697
Other ways to go about getting your point across the way you did just made you look stupid. But anyway, none taken and none intended on my behalf.
Why is what a dyno reads out so "incorrect"? (genuine question!)
https://www.sau.com.au/forums/topic/215846-r33-torque/#findComment-3814721
I was of the belieft that an accurate torque reading needs to be calculated with the cars gearbox and or diff ratios... by not entering them you wont get an accurate reading?
Im sure someone will confirm this
Edited by Granthem
https://www.sau.com.au/forums/topic/215846-r33-torque/#findComment-3814785
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
