The valves will usually leak off anyway over a few hour period, and the way i figured it was with the valve there it actually restricts the flow from the pump so i completely drilled mine out, just when starting the car you have to let the pump prime to fill back up the lines
The non return valves need to be there in case one pump shuts down. If it does then the other will pump straight back to the tank instead of the fuel rail and you could have a wrecked engine on your hands so you have the non-return valves to make sure the fuel only goes to the engine.
The same told me my engineer! But if we have two 044 and one blow and the car run with one 044 it will blow the engine sure!!
If we have one fuel pump like stock cars if it blow, simple the engine stop to work...
What is your opinion?
Also GTRgeoff what do you have to said for the green 33 post?
It's just Geoff mate. We aren't formal here.
You have to be running a fair amount of power for a single 044 to be running at the limit. The reason for running 2 pumps after a swirl pot fed by a lift pump is to protect your investment in an expensive engine. If you lift your power requirements beyond that of a single pump (in which case there is an argument to run separate fuel lines from each pump) then you must get new pumps that will deliver the power you require.
As for drilling out the non-return valves, they are a restriction above a certain flow rate, but should not cause a problem at the flow rates expected from an 044. If you need more flow, get a larger valve. And yes they will often allow pressure loss in a standing fuel system but every fuel system has that in common. The reason for their existence is to stop the fuel finding the easiest route out, and that will be a pump that isn't running and pressure loss in an engine being pushed hard is almost a guarantee for a meltdown. Sure it may be a little more expensive to do it properly, and not as ghetto or drift cool as drilling them out for extra flow that isn't needed anyway, but it is definitely cheaper than lunching a motor.
I have two 044 with surge tank and one walbro intank. The return from surge tank to fuel tank will have a stock fuel pressure regulator without any vacum so 2.5bar fuel pressure!!!
Geoff can a T04Z runs with one 044? All people here said me no in a topic! I need two! So if one stop work and the other continue to work?? What will be the result? A blow engine!!! Right?
If we have two and one stop work without non-return valves the fuel of the working pump will not go in the engine so we will avoid the lean running.
But we will have a little fuel that will injected in the engine... because the surge tank have 2.5bar fuel pressure..
So I will save my engine with this method? Or I will blow it too?
If you have spent enough money on your engine to truly need 2 x 044's then you should spend the little bit extra and buy a fuel pressure guage. If you have a Power FC, then any leaning out will cause knock and the knock warning light will flash. If you ignore the low fuel pressure and/or the knock warning then nothing will save you.
If you don't have the one way valves, some of the fuel will still go to the engine, just less than what would flow if one pump failed and you had non return valves.
Cheers
Gary
Cheers
Gary
I certainly wouldnt be running 40 psi fuel pressure in the surge tank, why not just plumb it up like everyone else does, it works fine?
Sidneykid so there is no difference in reliability either with non-return valves or without ?
Either with or not the result is a blow engine ? :rofl:
I have egt and wideband gauges with warning so I don't think that I need a fuel pressure gauge.
But think also.... if we have non-return valves and one pump don't work we will not understand it! Right?
So more dangerous!!
Maybe when the one pump stop to work to survive my engine... but if the car still works with one pump I will detonate it many times!!
But if you think that with 2.5 fpr at surge tank the one pump will feed the engine properly at low demand for fuel so I will still don't understand the non-work pump.. so if I don't put non-return valves better to don't use fpr to stop the fuel feed totally.
Adriano I like the idea of fuel pressure regulator at the surge because I will be sure that the surge tank is absolutely fuel.
Also if I choose to don't have non-return valves the lines will be empty so long try to start the engine.
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
