R34 Gtt Rough Idle Only
Guest TR34GT
Hi SAU Members,
I've read a fair bit about R34 GTT's running rough at idle.
The answers have ranged from:
  • Airflow meter plug check
  • Check ignition coil packs and replace if necessary
  • Boost leakage check
  • Airflow meter clean
  • Loose intake pipes check
My GTT has been running perfectly................up till yesterday. Now I've got the shakes at idle as well.
The only thing that has ben done to the car before the problem started, was the installation of the induction box we built.
(but I don't see that this could be causing the problem)
I need to know if getting a diagnostic check on the car is really the first thing that should be carried out, so that a whole heap of money isn't wasted on coil packs, etc.
Many thanks
TR34GT (Jim)
https://www.sau.com.au/forums/topic/215869-r34-gtt-rough-idle-only/
Well its next to the AFM so perhaps that jim?
What idle is it? Does it hunt the idle varing idle slightly as if the air con is on?
Does it idle better or worse on a hill?
Does the car feel slugish?
Edited by DECIM8
Guest TR34GT
DECIM8,
The problem was solved in accordance with the attached car care data sheet.
It was the bloody vaccum line. (annoyed that I missed it at night)
Many thanks.
Jim
CDS_No_2___Engine_Running_Rough_at_Idle_and_Load.pdf
Edited by TR34GT
