Guys, can you help me, want to use STD 350z springs on my v35 coupe for a modest drop, only used for day to day driving, also retain my STD shocks,is anyone out there using this setup, and what has been the results so far, [ride quality, and actual drop hight] my coupe is a 2003 model, also is there any difference in the STD 350z model springs 03-08. PLEASE, can someone help with some info. Thanks G.T.
https://www.sau.com.au/forums/topic/215872-lowering-v35-cp-std-350z-springs/
  • Replies 49
Posted Images
Did a fair bit of searching on this when I bought my springs and it definitely is a very small drop. can't remember about the ride quality, but 100% sure it is a drop. I would imagine it's a bit firmer. check G35Driver.com, its been done many times.
keen to know this also
from what i have read on g35driver.com this should lower the front approx 1" and the rear about .25"
Thanks waz, like you i here its 1'' then some one says its .5'' there doesnt seem to be a def/answer, even in the g35driver forums they get of the track, and start talking about coilovers, teins springs,etc, anyway i welcome your comment and help. Thanks mate. G.T. :)
I've got my 2003 Z33 springs sitting in the garage.
If someone wants to borrow them to fit, measure up the ride height, and do a lap around the block then I don't mind loaning them temporarily.
Thanks mate, some def/answers to this would be great, ill just keep pluging on. Regards G.T.
Thanks nismo, like i mentioned to Waz, have checked g35driver forum for this answer a few times but so far no luck, maybe someone out there has the answer, once again thanks so much for your comment. Regards G.T.
http://g35driver.com/forums/showthread.php?t=65190
Here you go. 350z springs will lower a coupe around 1/2 inch.
Later model coupes which came with 19's standard had harder springs so may not see as much as a difference.
The above will give you all you need to know about V35 spring rates and height.
Simply do a search on 350z-tech.com or my350z.com and get the standard 350z spring rates for the gives years and you'll have your answer. If you want to be 100% sure.
Otherwise, as a few have said, 350Z is lower and i believe more stiffer.
Hoo-ray, thanks nismo maybe getting somewhere now, so i take it a 2003 coupe should get the right results, that is 1/2 inch all round. Many thanks G.T.
Here's some more good confirmation to set your mind at ease.
http://g35driver.com/forums/showthread.php?t=211105
Tells you how to identify the type of z springs you have too. I will going down the Z spring path as well shortly for my sedan.
Edited by n15m0
No probs.
If you ask me, i think stock 350z springs will give you little difference and may not be worth it.
On my last V35 I used Tein 350Z H-techs. The drop was quite small and the ride was still very very comfy. You can even use G35 H-techs.
Tein designed these for a little drop, a lot of comfort, and i believe they were a progressive rated spring which gives you that added stability in hard cornering.
the problem is that suspension is a very personal choice and it totally subjective
what one person calls a "small drop" and "comfy", the next person calls a big drop and too hard
geoff, if you go down the standard 350z spring route, please let me know and provide some before and after pics for us if you can
i would be keen to do this also at some stage, but i would want to see how it looks first :)
i would be keen to do this also at some stage, but i would want to see how it looks first :O
Yes I think your right waz, ill sus it out a bit more, Iam shaw someone has done this mode in Aus and would have some detailed results,ill keep you posted. Thanks G.T. :)
nice! where did you get them from? i rang a few wreckers but no dice..
Got it from GT autosound at Newmarket...they advertised in the for sale section about 2 mths ago but their ad was locked coz they weren't a paid trader..I recalled them selling a set for $150...went and picked it up for $125 :nyaanyaa:
I suggest putting a WTB ad in the 350z-tech forum under the aussie classifieds..I dare say there would be more than a few Z owners that have their stock suspension sitting in their garages gathering dust.
http://www.350z-tech.com/forums/index.php?showforum=105
I will post pics of mine after its installed...picked up a full set of Z suspension (shocks and springs) out of an 05 model with 10,000kms last week. :P
Cool I'd love to see it & hear your opinion on what the ride is like :( I may go down the same track....
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
