Okay so the more i read the more confused i am...
so im just gonna ask the masters to give me a hand...
Why is your username Joe and &33? Is it Joe and Ampersand33? Is it Joe and and 33? Do you stutter? Is it a typo? Is it relevant?
Again I remind you to read the above mentioned disclaimer.
  • Replies 50
Yeah, great advice already given, only thing I can add is depending what your power goals are you can consider getting a R34 GTT SMIC instead of FMIC. If you don't have high power goals then that is a great option. However in saying this, once you do a few mods the bug will get you so you then want more and will end up needing a FMIC.......
I have also wondered this. ;)
well my thoughts are that its a typo and he was meaning to have it "Joe and R33"......just my thoughts.....
ahh yes the power bug will bite you one way or another mate....so its proably better off going with a FMIC and not really worry about a SMIC.....when i was changing my smic to a fmic i was like WOW the FMIC is really really tiny compared to the FMIC......and if your going to boost it up then my advice which is what i am going to get done soon is get a electronic boost controller and a aftermarket fuel pump......and safely enjoy the boost to 10 psi and i personally wont go anything higher then 12 psi.....10 psi is a safe boost level and is more reliable
Joe, dont listen to these fools.
All you need is:
an atmo blow off valve - $150
4 inch exhaust tip (its the only bit people see) - $50
Huge sub and amp combo - $200 on ebay or similar
Chrome hubcaps (much cheaper than rims) - $40 ar Super Cheap Auto
and spend $60 on brand name stickers for your doors (Trust Greddy HKS etc)
All up $500 and youl'll have a fully sick ride.
Remember to drag off every car you see at the lights, keep the drivers window down and the sub turned up. With practice you may even master the art of driving with the seat all the way back and fully reclined. (chicky babes love this)
All you need is:
Dont forget racing stripes. Oh oh and DONT lower it whatever you do! Those stickers are about 5rwkw each at LEAST.
There is nothing unsafe about 12psi and that is reliable too i had mine boosted to 14 drove like that for a year before it made funny noises
lol Guy so true
lol Guy so true
it really depends on the condish of the turbo i guess! a mate of mine has done the same as you, run it at 14 for over a year now and everytime i drive it still feels very good, no problems so far! unlike mine, the old owner must have boossted it and so! so when i was running 14 the bearing shat itself on the second day
if he goes all out and puts enough stickers on it, it will lower itself.
:D
Don't forget the mandantory LED lights for the windscreen washer squirters!
Thats another 2-3rwkw
:D
Oh ... and have a 'fake' roll cage made up with exhaust bends! :D
Edited by RubyRS4
hahaha also there is cardboard estra wide spoilers and side skirts!!
hahahahaha
also with the name...
yeah i did a typo and i dunno how to change it back now... :D
PM one of the admins, im sure one of them will be nice enough to change it for you. Then again arent they all the greatest :D:D
Also, remember to have your right arm hanging out the window and left hand on the wheel at 1 o'clock staring down anyone that dares to look your way(yes I'm talking about that elderly lady over there)... makes you look sick... and looking sick = kw :D
and if your ever losing a drag against a VN, yell out "f**k the po-po", instant kilowatts, its like a NOS effect
but back to a serious note, there is MORE than enough information here to get you to the power you want.
but first, cooling and flow, cooling and flow.
Edited by Damo_R34
dont forget to also put chromes wiper thingys on.....they = kw too bro.....and you got to have a fully sick subwoofer mate.....neons galore.......and all those things hanging from your rear view mirror.....race pedals....they all equal to mad street credz mate
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
