Hi Guys,
needing some help with a part for my series 1 stagea.
LH Tie rod end.
Any ideas ?? The auto shop is looking at a skyline one but unsure if it will fit until try.
Stu
hey bud i got one gen nissan tie rod end which i bought still in box if ya want it $100 cost me 140. just have no use for it as i got mine rebuilt as there was only one gen one in australia and i needed 2. cheers bernard.
cheers everyone, looks like the skyline part they ordered will be OK. Find out tomorrow i guess :(
$100 retail from Nissan, I will put the part number up once I get it in case anyone needs to know.
  • 9 months later...
buy aftermarket
its only like 40.00 more for a pair
The R33 tie rod ends are half the size of the stagea end, they have nearly 10mm play in the housing on the hub... most definately not a SAFE replacement.
3 different tie rods outers for Stageas, depending on model, year, 4wd/2wd, MT/AT etc
48520-0cu25(2wd)
48520-15u25(4wd)
48520-23u25(4wd)
2 different for R33, both are same part # as 2 of the 3 Stagea tie rods.
48520-15u25(2wd)
48520-23u25(4wd)
best to ensure you are getting right part for your car. pm me your vin and ill let you know.
I am not 100% but think the correct one is an R34 GTR. I went through this a couple of years ago. It was the fourth one I got from the wreckers that was correct.
From memory the first one was for a smaller dia tie rod. The second was the correct dia, but the threaded section was too long. I cut it shorter but then discovered the thread depth was now too shallow. The third was the correct dia and length but the taper was too small.
Fourth time correct. The length from the center of the taper pin to the end of the threaded section is approx 90mm.
It was a sod of an experience. And verx exxy, as with allthe running around I chopped out two tyres.
well i've ordered the 33gtr tie rod, hopefully its right, my reasoning behind it was that the 33gtr/gtst/ stagea all have the same chassis, so i figured the steering and suspension would be similar, anyways ill find out next week when it gets here
also interesting to note that extension housing seal is the same as 32/33 rwd's and also subaru 4wd's
  • 11 months later...
how did you go? i have a S2 stagea and I ordered the R33gtr tie rod from bursons.. went to install it to find the threaded part far too short to fit the nut and split pin back on.
Look at my previous post, it gives all the pitfalls.
  • 3 weeks later...
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
