Hi all,
Got an R32 GTST, installed some nice pioneer splits in the front (kevlar ones) a few years ago and some cheapie clarion speakers in the back and a 10" sub ported slightly incorrectly and has a very deep response. all hooked up to 4 channel kenwood amp.
Now the rear speakers are blown, i want to replace them, but on the cheap.
I'm also missing a lit of mid bass, the sub is gives deep bass ok, the splits gives mids to high trebs but seem to miss alot of the mid bass and midrange. its like most of the sound i hear is from the tweeters and the sub.
I never bothered dynamatting/or putting that rubber deflector thing flexorb on the back of the front splits)
Does this have a large effect?
Also i was looking at these for replacement rears. Just simple 6.5" "paper cone woofers" that'll hopefully recover some of the midrange i'm missing.
http://www.jaycar.com.au/productView.asp?I...mp;SUBCATID=396
Anyone had any experience with these? should i even bother with these?
Also as a note i'm not going for loudness, just hopefully more quality, half the stuff i listen to is jazz and cafe style music.
I have found a lot of the jaycar gear to be quite reasonable for the money, but in your system I would probably spend the money on sound deadening the front doors (a tin of underbody tar is cheap, but messy- found at autobarn etc, or propper matting - more $$ but easier) and forget about the rears.
A propper enclosure makes a big difference, even a good set of speakers will be rubbish if the enclosure is poor, and mixing and matching different speakers wont help.
If you do go for the tar option - I use it all the time, be careful, it sticks to everything and wont come off. When using it, mask off the area, and wear thick rubber gloves and tie garbage bags on your arms up to your arm pits! Its cheap and messy, but works really well - I dont bother with anything else and I have built my share of systems :D
Thanks for the reply, i'll go with sound deadening..
now.. anyone know where i can readily pick up some Dynamat stuff in Melbourne?
You could talk to Jaycar about sound deadening. They have plenty of materials;
http://jaycar.com.au/productView.asp?ID=AX...=&SUBCATID=
Never given it a try though, let us know how it goes ;)
Hi all,
I haven't heard the Jaycar speakers you noted but have just heard a set of Response 6.5" in the rear of a S15 driven only by a mid range Kenwood head unit and I was very impressed.
They are a bit dearer than the ones noted but my impression of Jaycar stuff has just gone way up.
See ling below.
response speakers
yeh will prolly go for the 2-way 6.5" jaycar speakers.. its $99 for the pair rather than individual, so definately a good buy.
(oh as a note the ones i was looking at were 8ohm home speakers rather than car ones.. and so are sold individual basis)
I've sound deadened the doors with 3 rolls of dynamat.. wasn't enough to fill the whole door inside skin and panel. but got to at least 3/4 of it.. so mainly did the area around the speakers.. added some focal plain chant foam bits too..
the outcome..
much heavier door.. prolly added 2-3kg's to each door.. and u can definately feel it.. when opening on an angle watch out.. u may forget the extra weight and wack your door against something..
The sound.. when i first heard it.. i'd say definately a more noticeable punch from fronts.
hrm.. i'm not sure if it was worth the ~$180.. however.
Edited by quink
I have Jaycar 6.5 inch Kevlar Splits up front and they are fantastic. I also have a 12 inch carbon fibre jaycar response sub that is absolutely awesome! Top stuff and really cheap too.
    • Consider a 35 too...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 😃
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
    • Correct. The ECU cannot read oil temp. (Well, I think it probably can in some situations. I did have the thought of potentially repinning the ECU when I was doing oil pressure). I am using this into the MPVI dongle, so that the MPVI dongle can read oil temperature. It is attached to a VDO gauge which is obviously calibrated to whatever curve the sender actually is using. This would be easy if I could setup a table of voltage to temperature like many sensors, but it appears I cannot do this and can only setup the transform rule which appears to be Input (voltage) x Multiplier, and add an offset. This to me means it MUST be linear. So it may be a complete waste of time wiring this into the ECU. The idea was that the MPVI3 has standalone logging. I wanted to use this instead of a laptop with serial cable (for wideband) for long datalogs. Given the wideband also has electric interference, I may never trust this either in a world where the serial wideband and the analog output wideband do not agree. Last time I did a trace I could see the two wideband traces follow each other, but one was a little leaner than the other. I plan on playing with voltage offsets and actually driving the thing to see how close they correlate. If they never correlate... then, well, maybe I'll never use either. Ideally I'd like to have the Analog wideband read ever so slightly leaner than the serial one, because the serial one is 'correct'. Tuning the car to be ever so slightly too-rich would be the aim. Not needing to have a laptop flying around in the footwell connected with cables is... an advantage. About the only one from the forced upgrade to MPVI3.
