Hey all,
I am about to buy new coil packs and before parting with my hard earned cash would like any feedback from people who have gone though the process of identifing ignition issues on their rb25's
Ok this is the current situation.
mods = pod / full exhaust / fmic / upped boost (using turbo tech)
R33 gts25t series 1
Previously :-
running 12.5 psi on stock ecu , stock turbo, and slight correction with safc.. Used copper plugs bcp6re (copper .8mm heat range 6) and the car pulled all the way to redline with no worries, no R&R no missing coughing farting nothing.. ran sweet, no black smoke on boost or gear changes..
Current :-
On the weekend, replaced 20000 km old copper plugs with new iridium plugs (.8mm heat range 6) , removed safc and wound boost back to 8psi. get a little bit of missing and hesitation no under load..
please note : the safc was never 'tuned' only had -1 % correction from 2500 rpm to red line which effectively bought me under the r&r threshold and allowed smooth power delivery across the rev range @ 12.5psi.. Well thats what I was thinking at the time..
Considering when I had the coppers in everything was sweet and now the motor runs smooth but missing under load on 8psi, is it wise to just spend the money on the coil packs and be done with it? Or revert to coppers.. The rationale behind switching from copper to iridiums was to increase the service interval on the plugs.
What do others think? Coils or cheap ass plugs again?
Edited by turbs33
you will find a lot of cars getting up past 350 rwkws with the standard coils, mine included.
generally my rule of thumb is! if you have a problem? what was the last thing that i touched that was ascociated with the problem?
look at that first as its more then likely the reason for the issue.
there could be multiple issues with your car from the wiring where the safc was removed to plug gap, plug choice air leaks etc.
dont just fork out $$$$ for coils if yours were working perfectly before you touched it.
mine handle 24psi daily with no issues at all.
Yeah mine went over 350rwkw too.
I would have put coppers back in there. Increasing service intervals doesnt generally work.
Iridi's never last thier cost in terms of km's ive found. They are usually in need of replacement before their 100k
Did you gap the plugs yourself? You could have damaged the tip (they dont like being touched really)
I'd go back to coppers, the exact same plug you had before and see
Trident, I wound boost back as i was missing so figured id drop boost to try and aleviate the problem.
The iridiums i put in were gapped .8mm standard.. Cant remember the part number but its the one without the -11 on the end.
The coppers i pulled out looked really good for 20000k's actually looked like they could be re-gapped and last another 5-10k..
I will replace the irid's with the coppers i took out after checking the gaps and see if the car likes them better..
I spent some time down in the wiring loom ensure there were no shorts , exposed wires and the like when removing the safc... I am relatively confident the problem does not exist there. Though to my amazement there has been alot of wire hacking in there in the past, can see all the tape up wiring.. I will return there if coppers gapped right at 8psi cause me issues.
Thanks guys for the input, you have convinced me not to spend the moeny and to get off me ass and put the coppers back in...
unique1 lol read the post i said the ones without the -11.. meaning i got .8 mm plugs..
andhow problem solved.. f^cking cracked plug.. :) there ya have it.. pays to check everything properally as its going in..
Also i notice that the bcp6es are a taller plug then the bkr6eix <- is this not the correct iridium for rb25?
the above mention coppers seat into the coils so much better due to their height..
I am going to stick with my coppers for now 5x bkr6eix for sale 50 bucks plus postage. any takers????? oh they done 29 km's
Edited by turbs33
Standard coils are great when in working order. Leave them alone.
x2 500rwhp @ 1.8 bar on stock coils. The only reason people see a diference going to splitfires is because thier old coils were dirty/busted and the splits are new. I did the dremel the inside trick and they were like new.
dont go paying pounds sterling. go to your local auto parts store.
buy the coil pack for a 3.8 litre v6 holden commodore engine
1 meter of 8 gauge wire
3 meters of 16 gauge wire
one diode with the capabilty to with stand 12 volt 100 amp's (ask the guy at dick smith's)
6 spade connectors to plug into the holden commodore coil pack
6 1 meter long bosch ignition leads
6 Ngk spark plugs with a .8 ml gap
then go to your local auto electrician and tell em you want a wasted spark system, and need the car back by lunch time..... ;)
After my latest episode, it makes me wonder how many people actually need new coils or if the problem is something else..
wrong plug etc...
Can anyone comment on the iridium bkr6eix being the incorrrect plug for a series one r33? the top part of the plug just is not as long as the coppers i mentioned abaove and hence does nto seat as well into the actual coil...?
Anyhow I am sticking with the coppers.. Just curious.
Edited by turbs33
hey dude, i was going through the same problem! i purcashed a pack of iridiums! and my car was missing pass 4000RPM and was missing to redline... I had em on for about 4months and i got really angry and it took me that whole 4months through researching through the fourms and so i decided one day to go to Supercheap and buy these cheap spark copper plugs! i cant rememba which one it was.. but it totaled up to 24.90, they were pre gapped to .08mm and heat range was 6 i think? im not at home atm so yeh when im home i'l put up
Yeah there the coppers i had been using and am now using again..
bcp6es i think .. heat range 6 and gapped at .8mm and never miss a beat..
But F'it i just left the coil cover off and that saved 5 mins on a plug change for the future.. beside once ya do it a few times it takes like 30 mins max if ya dont piss arround :blink:
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
