Item: Complete Stock R33 Exhaust
Age: Has Come off a 1996 R33 Skyline Coupe
Condition: Good condition, no scratches on bottom.
Price: Make me a offer (open to Negiotation/would be willing to swap for some other aftermarket parts just ask)
To Fit: Series 2 R33 Skyline. I am unsure if it would fit a series 1
Contact: 0407571554
Currently still have the stock front/dump pipe on the car but it will be removed within the next two weeks.
https://www.sau.com.au/forums/topic/215922-stock-r33-exhaust-4-sale/
