  flake32 said:
just thinking is it worth the $800 for a remap?,has any one heard of engine failure due to this?..just wana do the righty by my engine...thanks
by the way the car is running 10psi,and has a big fuel pump,i have been giving her a bit of a thrashing lately, hope ive done no damage......
it might be ok. i was running a stock r33 rb25 turbo on my rb20 and untuned it was leaning out slightly on 13psi above 5500rpm. only to like 13.5:1 afr. your running less boost so it might not be leaning out too much but i think its best to get it atleast checked with a wideband o2 sensor just to know whats going on.
but if you really want to do right for your engine go for a remap, if not a safc.
it will b ok as the afm will compensate for the extra volume of air entering the engine. although u will find it will b running a lil lean as the boost has been raised. but it will do this even with the stock turbo. fittin a apexi SAFC-2 will fix this n b cheaper than a remap. it will also give u more top end power as the a/f ratio will b at a more power productive level. remember tuning is the most important aspect of the power and engine makes. an engine could hav all the bolt on's in the world but its the amount of fuel and air, and when it is ignited that makes the power
Absolutely fine, I ran my RB20 with a series1 33 turbo for nearly a year on 12psi and regular heavy beatings :D
Oh and unless your fuel pump is dying (which it's likely not as you say it's got a bigger one) it's likely running rich as opposed to lean, what an SAFC will do for you is a cheap way to lean it out a bit and gain some more top end power.
I didn't bother with any of that shit and waited till I got the 30 in before I got it tuned properly (remap).
Edited by bubba
I am about to put in a RB25 turbo from an R34 on to my RB20, and I was advised to get it tuned straight away as it will throw out all the air to fuel ratios......
If you boost the RB25 turbo to 12-14 psi, i would be a little concerned about it leaning out......
Edited by Douse
it will but not by much. the extra flow will be picked up by the afm and the ecu will do its best. like i posted earlier i was seeing afr's of around 13:1 on 13psi, so not too bad.
My 20 w/25 turbo with stock fuel pump was seeing around 13.5:1 but boy did it go like a shower of shit heh.
Was pretty lean so did the fuel pump and untuned it made 246rwhp (@12psi) so I was pretty happy.
A tune will pretty much get rid of some of the lag (by smashing in timing down low) but I didnt see the need at that level, I preferred to save my money for the 30+bits.
Edited by bubba
i ran a 34 neo turbo on my redtop 20 for ages with no tune, was very very rich, when it did go on the dyno the afr's dropped of the scale to below 10:1
got an old style safc tuned on it and picked up 50hp and heaps better fuel economy:)
hey guys while the suject is up i also put a r33 stock turbo on my rb20 and its untuned i havnt been thashing it but whenever i do give it some it has no power since the new turbo is that normal
Edited by ACTIV32
  bubba said:
No that's not normal, can you quantify "no power"?
yer well the power is probally equal to a stock r32 with its original turbo
i put it in my self and i checked everything twice i dunno, bizzare
i thought you had to get a tune for it to start giving th correct boost
Yeah did you use the actuator off your original turbo or off the new turbo?
R33 actuator is 5psi, R32 is 10psi. If you are using the R33 actuator and do not have a boost controller of some sorts then yes, it will feel rather gutless :thumbsup:
R33 actuator is 5psi, R32 is 10psi. If you are using the R33 actuator and do not have a boost controller of some sorts then yes, it will feel rather gutless :rofl:
well there is my problem i was going to use the old acuator but i think thats whats blew up my stock turbo and yer t is stock cheers for the help guys
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
