hey guys
i have some r33 rims on my R32 at the moment and i picked up a Set of r32 rims for $100 bucks with rubber. i was thinking of powder coating them black, as I’m going paint my brake callipers red. What do you guys reckon would work best with the rim colour, some said do shadow chrome and others said get a chrome machined lip.
any way i have attached a picture of my car, so you can see the paint colour let me know what you guys think and what colour would work best.
My Car
What it might look like?
Thanks niran
Edited by niran
https://www.sau.com.au/forums/topic/215982-what-color-rims/
Yeah I like that whole stealth look when you lower the car on stock rims then paint it black.
Looks seriously TUFF!
And get rid of that, what looks like to be a R33 GTR spoiler and take that Nissan sticker off ya windscreen.
https://www.sau.com.au/forums/topic/215982-what-color-rims/#findComment-3815465
ahahahah! yer the spoiler was on there from the guy i bought the car off. i havnt botherd to remove it incase its a different color under there, and i dont have the money to paint the car back agian if it is. so yer have to remove it when i do a respray off the car.
https://www.sau.com.au/forums/topic/215982-what-color-rims/#findComment-3815471
hey guys yer. ill have to see about the spoiler thing. but abu whos car is you'r friends the first car" my car" or the one i used as a "maybe could look like" car ahaha.. also yer ill remove the spoiler and see what color its under there.
so far black rims is the way :(..
thanks guys niran
https://www.sau.com.au/forums/topic/215982-what-color-rims/#findComment-3816891
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
