ok....well i am looking 2 get an engine swap in my R34...and i was wondering if anything on the body would need to be changed if i was swapping a RB25DE to a RB26DETT...i know it is .1 litre bigger...but is there anything i would need to change to have a GT-R engine in my R34? I was thinking if something needed to be changed then it would most likely change everything like i would have 2 get a GT-R Hood and body kit...but im not sure...so plz help me with this...and if something needs to be changed then tell me everything that needs 2 be changed like if i needed a GT-R hood i would also need a GT-R body kit...Thanx 4 the help :)
youd need to change very little. certainly not the body kit , as that has no bearing onthe engine. the rb26 doesnt sit any higher than the rb25, though if you wanted top mount turbos you may have to lok at bonet clearance. (more of an issue with rb30s as the block is higher.
youll need a new ecu, remap and perhaps it wopuld be wise to look at uprated drive shafts and certainly brakes and suspension to handle the ike from 200 ish bhp to 300plus.
lot of work mate ...but can be done
thanx mate!
What you need:
RB26DETT
RB25DET box - NA boxes will not be able to hold that power and RB20DET boxes will strip gears and do in bearings at that level too.
RB26DETT loom - You will have re-wire the whole ECU system
RB26DETT ECU - Self explanatory
GTR or Higher Fuel Pump - NA fuel pumps will simply not supply enough fuel
Fuel Pressure regulator - You will need to replace this for the fuel system
RWD sump - I know Rb 25 AWD and RWD sumps are direct fit but I dont know if a 25 sump will fit a 26
Front pipe/Dump pipe will need to be changed too
Then there is everything you really SHOULD change.. but not absolutely essential for the engine to work
Diff - Large power and open diffs do not go well together
Brakes - I like knowing I can stop.. especially as I am assuming your putting in a 26 to go faster.. going faster means you will need more braking power
Exhaust - A stock GTR exhaust is the LEAST you should put on.. You dont want to have all this power and not get the most out of it
Front Mount Intercooler - Stock ones are fine but you will have to source one as the RB26 engines dont usually come with them and you will need it to complete the intake piping
You may need to chop/change the front bar to allow for a FMIC
A boost gauge is a good idea too
And a stock bonnet will be fine
Got a Lazy 10K?
Edited by GTS4WD
Funny that.. guess what I found in the for sale section?
http://www.skylinesaustralia.com/forums/Rw...um-t215977.html
You could always PM him an ask here he got it from if you dont but it off him
Thanx alot man...
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
