Hi guys,
just about to get my car service and thinking about getting plugs changed as well
well, the problm is.. after reading alot on the plugs topics.. lots of people here are recommend thing like .8 gap with 5 heat rate ..
but, i'm getting IRIDIUM BCPR5EIX-11 for my car
what you guys reckon about these plugs? will they be ok on my car with mods like.. pod, fmic, 3'haust and so on
and will they make any back fire? (at the moment, I have no problem with it)
Cheers
Edited by subie
https://www.sau.com.au/forums/topic/215987-spark-plugs/
Get some BCPR6ES plugs man
NGK copper - they come gapped to 0.8mm (you'd double check of course)
Never had a problem with them running up to 15psi, thats whats currently in my car and hopefully it should see in excess of 18psi next week without any issues!
I've heard there is no extra gains to be seen with the IRIDIUM plugs plus the element is supposed to be quiet brittle which causes them to break after a short period of time
Plus there is no way I'd pay that much for spark plugs!
https://www.sau.com.au/forums/topic/215987-spark-plugs/#findComment-3815627
I am running iridiums in my RB20 and was having no problems till I upped the boost to about 12-14 psi
It then started misfiring at high RPM.
Took em out and they were gapped to 1.1mm, so reduced the gap to 0.8mm and have had not a problem since. The car runs great now.
Edited by Douse
https://www.sau.com.au/forums/topic/215987-spark-plugs/#findComment-3815698
i was always told by my reputable mechanic to "MAKE BLOODY SURE IT HAS A 7 IN THERE"..refers to heatrange im told :S
i just go into autobarn buy coppers with a heatrange of 7...thats all i know :(, and all i need to know.
https://www.sau.com.au/forums/topic/215987-spark-plugs/#findComment-3817208
BC and BK is the thred type. they are both the same except the height from the gasket to the top terminal on the BK plug is 2.5mm shorter than on the BC plug. so if you use the BK plug you coils may not make a good contact wih the spark plug.
its all in this chart:
it wont let me upload my chart for some reason. i'll try again later.
anyway its sort of like this one, but the one i have has heaps more detail.
http://www.wakularacing.com/NGK%20CHART.gif
just use the BCPR6ES plugs, they are proven to be good. if you cant get them you can also use BCPR6ES-11 and regap to 0.8mm.
https://www.sau.com.au/forums/topic/215987-spark-plugs/#findComment-3818554
