Gramlight 57Pro
Driven on once to a car show!
18x11 +12 all round
no tyres
$3200 delivered aus wide
local pickup in SA for $3100
to suit widebody cars and GTR's
they came off of R34 GTR with 275/40/r18's stretched with -2.8 camber - stock guards - sat flush :)
gunmetallic grey centres - polished dish
https://www.sau.com.au/forums/topic/215988-fs-18x11-12-gramlight-57pro/
actually just found this
and for the record that is with a 315/35/r18 bulging off
255/40 or 275/35 would be much better suited to standard gtr guards
Edited by Hella Flush
thankyou for the compliments :D
wheels are under negotiation atm - however first in with cash will take them
dont be afraid to make reasonable offers
price drop 3100 delivered aus wide or 3k local sa pickup
last chance
ive had an offer of 2800
if noone can beat that they are sold tomorrow lunchtime
ring me any time of the night tonite/tomorrow morning 0412 889 127
dont miss out!
Hi, im pretty sure the rims u have in your first post arnt the same rims you have on that blue car..
The rims on the blue car have bolts inside where as the first pic dosnt..
canu please PM me clearer piks
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
    • a stock / option or aftermarket?
